Thanks, effectively I’m running on limited budget
Biggest issue is the two modes that resonate more time than other sounds, mainly 70 and 140 Hz but cannot trust accurately because I used a older mic that was not made to calibration, and the iphone mic: more or less coincide on the main lower end modes frequencies but not on the decibels.
I will purchase a Umik 1 as soon as I have my subwoofer (Genelec 7050 ordered). When rolling off on 85 Hz left and right channels on WiiM Ultra (just by activating sub output automatically applies the roll off filter) things improve a lot, leaving just one mode at 140-150 Hz and the messy reflections on the right speaker.
Thanks for the suggestion about Dirac live, but I find some fun on hand made corrections, so for instance I think that should go with REW and UMIK 1 or Behringer.
I have the impression, maybe just my imagination that a lot of EQ give some unrealistic feeling or is just WiiM auto correction is very inaccurate. I can tolerate imperfections and some resonances, that make part of what happens when I play my piano but don’t like when prolongated “hummmms” invade the room and disturb mids and highs.
Eventually I correct another 3d mode that appears at 310-330 Hz, I suppose is a mode and not a reflection because this prolongation sound and appears both in left and right speakers, or if I place one just at the middle of the room.
I had a Genelec F Two some days for trial and another very little 42 Hz mode appeared, but was easy to correct.
I will try to fill the bookshelves by toys and some gym light material to help diffusing sound from the right, yesterday au discovered that also placing a chair on the corner attenuated low end (unfortunately not adding clarity, just dumping the lows)
Post edited: nice to read REW simulator on rooms acoustics, I enjoy learning a little of that field when trying to improve my music experience, that makes part of the fun! A reason to avoid automatic software for instance, I can live with imperfections but I can’t live without knowing where and why they appear.
