nanook
Zero - current - check:
There's no trim-pot for the bias current nor for output offset voltage; the output stage obviously lives with a fixed value and all you can do is check the bias current as described.
The resistor defining the bias current seems not to be determined in production (NAD did this) but they fitted a 68 Ohm resistor according to the service manual that is attached.
Capacitors:
There are a lot of electrolytic caps in the signal path, some of them even as low as 0.47uF. Since the circuit is quite "high-ohmic" in many places, you will not notice a dried out cap until it reaches the nF regime, but you might notice a "fat bass" because the HP-filter formed by the dry cap and the DC-return-path will generate some harmonics. I'm speculating
If you want to really use this amplifier, my take would be to change all except for the reservoir caps. The 0.47uF, 1uF and 3.3uF even suggest for a replacement with film caps (polyester, so MKT or MKS are definitely good enough).
But I have already outed myself as the member of the "replace-all crowd".
If you have an ESR meter - or can borrow one - this is the first step.
Volume Potentiometer:
Those were not bad so I'd only replace it when it's really bad or if it's not possible to eliminate the scratching with Teslanol T6.
You can apply a sinewave with a frequency that your multimeter can measure correctly (many multimeters are specified up to 400 Hz only, but in the end you just compare the values for L and R, so the absolute value is not important)
Loudness: off
Tone control: flat
Then start with volume fully cw and check the ac voltages L and R. The signal source should be set such that the amplifier is not clipping. Just dial the level such that you measure e.g. 10V ac at the outputs. Then reduce the volume by e.g. 5dB and compare again, then 10dB....
Note: Most potentiometers do have significant L/R deviation for attenuation of 40dB and higher.
Have fun!
Capacitors:
Loudness: off
Tone control: flat
Have fun!
