Importance of lowering distortion generated on the input current of speakers
ASR fan
Can anyone explain how input current distortion as demonstrated in this video may or may not be important? Does it translate into distorted sound, independent of the amplifier being used for example? Also is it a measurement result which is offered by any speaker unit manufacturers? And should it be?
Current distortion is due to the principle - V/Z(nonlinear). Explained on my web:
Current drive, however, would lead to freq response modulation according to impedance plot. So, some reduction in distortion is possible, but not trivial.
Another complication is that you need to feed each speaker driver with the constant current, to get some effect, which excludes passive crossovers. And every driver would need FR EQ of the constant current.
Note: I did not watch the video. I do not watch any audio videos, as it is time consuming and time is precious, and usually the value of information is low.
Going through your link it seems that the benefits can be reduced odd-harmonics at higher frequencies, which is also what Dali says their SMC achieves with normal amplifier setups. So if we go back to the video above, although the impact is seen at all frequencies, is it fair to assume the benefits are only heard at higher frequencies? Because other sources of distortions are more important at lower frequencies?
I think the question you should ask is not are the benefits heard only at higher frequencies but can you actually hear a difference of 0.05% in THD at higher frequencies.
In my understanding, Dali has never claimed SMC lowers the total distortion by 0.05% or any other specific amount at any frequencies. But they do show improving input current distortion in the video above, and I was just trying to figure out how important it may be (if at all). They certainly do a lot of marketing around it. And it seems Purify has spent a lot of effort in the same area, some of which probably inspired smc gen 2 in the epikore drivers.
I watched it so you don't have to. Brief summary: SMC motors have a pole piece (and part of the top plate too, in the more expensive models) made of a granular soft magnetic material with fairly high permeability and saturation flux, and much lower hysteresis and eddy current losses than the low carbon steel typically used for such parts. The CEO demonstrates lower current distortion in drivers with SMC motors compared to an older DALI driver with a steel pole piece.
So it's not about current drive, but a different method to a similar end.
If you mean "does it show up in acoustic measurements", the answer is yes. For drivers with simple motors, current drive typically results in a quite dramatic decrease in odd-order (H3, H5, etc) harmonic distortion in the midband—20-30dB reduction in H3 is not unusual. On the other hand, distortion often increases in the range near the driver's low-frequency resonance.
The main thing is, we don't want it to be higher than other mechanisms of distortion. Once the contribution of current distortion is below that of, say, suspension non-linearity, the focus needs to shift.
It's a nice video and makes me appreciate the engineering sense of Dali.
I thought this worth sharing from Mr.GPT:
Question: Is speaker input current distortion proportional to linearity of L(x)? (Inductance vs. excursion)
Answer: In principle, yes — to a first approximation, distortion in the input current of a speaker is directly related to the nonlinearity of the voice coil inductance L(x). But the relationship isn’t purely proportional; it depends on how L(x) interacts with the signal and other parameters.
Here’s the breakdown:
The voice coil impedance is
Z(x, i, ω) = R_e + jωL(x, i).
When L(x) varies with cone position, the instantaneous inductance changes with signal amplitude (since x follows the input current).
This variation causes current modulation because the back EMF depends on d(L(x)i)/dt. As the cone moves, the inductance changes, altering the effective impedance.
The result is amplitude-dependent current, i.e., current distortion.
In small-signal terms, if you expand L(x) as
L(x) = L0 + L1x + L2x² + ...,
then distortion terms in current are approximately proportional to these coefficients (L1, L2, etc.). So yes, more nonlinearity in L(x) means more current distortion.
However, it’s not strictly directly proportional, because:
Other nonlinearities (Bl(x), Cms(x)) also affect current indirectly via back EMF.
The effect depends on frequency — at low frequencies, L(x) distortion is negligible compared to Bl(x) or Cms(x), but at high frequencies it dominates.
The shape of L(x) (symmetric vs asymmetric) determines which harmonic orders appear.
So, in short:
Speaker input current distortion increases with the nonlinearity of L(x), but not in a perfectly proportional way — it’s one contributor among several, and its influence grows with frequency and signal level.
Current-drive seems to be trending again after -what?- 30-40 years?
I remember a nice paper about it building an active speaker with tube amps(!) back then but can't find it anymore.
Personally, I find it quite interesting. The math involved makes my head spin, but I understand the process.
Found this measurement in one of the Dali whitepapers. It is a bit funny how they show all these technical graphs, but then don't show the actual acoustic THD results, incl 2nd, 3rd etc harmonics for the end product at different levels.
... and that is what you need. Just this, all else is speculation and a half-way result. And, as always, marketing and marketing. It is close to useless to read company presentations.
It has some value. We know that the majority of good speakers have distortion around 0.1-0.5% at comfortable listening levels. So if the current distortion is well below that, it will not the major contributor.
My earlier post was kind of hinting at the fact you can tell a lot from a Klippel L(x) graph if current distortion is a significant factor.
For example two drivers, note the scales of the graphs:
Below: Purifi PTT8.0X04-NAB-02
16mm pk-pk variation ~0.002mH
Below: Scan-Speak 15W/8534T00
16mm pk-pk variation ~ 0.08 mH
Nearly an order of magnitude less L(x) variation in the Purifi. Also note one is more symmetric while the other is more asymmetric, this tells us something about the harmonic structure. Symmetric non-linear L(x) curve = odd order harmonic products / Asymetric non-linear curve = even order harmonic products.
You dont NEED magic ingredients though - here is the KEF uni-Q from R300 (different data source now). Nice and linear over the usable excursion range.
.... And should it be?
Current combined with magnetic field generates force, which drives the membrane to acceleration which makes the sound. The varying inductance of the coil may distort the drive force, if the amp would only control voltage, but not the resulting current.
At higher frequency the inductance counts, hence current drive could help. The OEM could dismiss contempotary measures like a copper sleeve around the pole piece.
But at lower frequency considerable movement of the coil in the magnetic field is required. The field is not constant over all the coil's excursion. Hence, current drive won't help.
I measured this, on woofer acoustical side, many many years ago:
But remember, the current drive needs frequency response equalization before the signal goes to the speaker, otherwise it copies the impedance response, in case of the woofer the resonance curve.
Unless I'm missing something, use of the "SMC" material probably won't automatically improve L(x). Motor geometry (the pole piece in particular) and shorting largely determine L(x) performance. Additionally, L(x) tends not to be very significant in harmonic distortion measurements because excursion is small at frequencies where inductance is dominant. Intermodulation distortion is where you'll see the effect of L(x).
Right you are, I'm getting mixed up thinking L(x) plots include the dynamic inductance changes due to back EMF, when in fact they show L with the voice coil essentially held static at that position.
From what I've read, input current modulation does tend to show up best in IMD plots rather than pure harmonics.
I also measured something like this some years ago, but only one driver tested.
Dayton ND91-4 with voltage drive:
Dayton ND91-4 with 20R series resistor and EQ to match the voltage drive response:
I know this is an old thread, but I thought I mention this, since no one else has.
L(x) is not the only contributor to current distortion. You also have L(i). Esa Merilainen does this experiment where he measures current distortion before and after gluing the voice coil in place so it doesn't move. He shows that while H2 drops significantly with the fixed (blocked) voice coil, H3 and H5 remain unchanged.
Link to the paper: Comparative Measurements on Loudspeaker Distortion:Current vs. Voltage Control
