Sound stage- the perceived depth/width/ height of the (virtual) "stage" you are listening to the music performed on.Imaging and Sound stage what are the differences?
thank you
jinx ;-)Sound stage is the illusion that instruments or vocalists are presented on a stage in front of you. The width and depth of the stage will vary with room geometry, speaker type, speaker placement, acoustic treatment, etc.
Imaging is the illusion that an individual instrument/performer is placed discretely within the sound stage and given an appropriate size/shape.
It's all an illusion.
You kind of already asked that. Dont be that guy.Imaging and Sound stage in headphones how are they perceived?
Well... as far as the brain is concerned nobody really knows other than the location in the brain and when it is or is not perceived.Imaging and Sound stage in headphones how are they perceived?
I don't think that's much of a factor. There are too many different ways to record & mix a recording.What genres of music are best suited to perceiving soundstage and imaging?
any sample videos?I don't think that's much of a factor. There are too many different ways to record & mix a recording.
It's probably easier to locate a single instrument (or singer) in a small band than in a full orchestra, but the full orchestra isn't always playing all of the time and you should be able to locate the various sections left-to-right... to some extent.
There's also a standard seating arrangement with a classical orchestra and classical music fans are aware of that so that probably helps with the illusion. Or if you've seen your favorite rock band live (or seen videos of them live) that memory should also help with the illusion as long as the mixing engineer followed the pattern.
amazing imagingThis has obvious imaging parameters.
Video is not availableThis has obvious imaging parameters.
Yeah, this video pains us both. It's the same Ahmad Jamal - Crystal - Avo music video on YouTube that we have exchanged messages about because it won't open for you.Video is not available
Strange question.What genres of music are best suited to perceiving soundstage and imaging?
Why do you suggest parallel to the wall? I would have suggested speakers pointed directly at the listening position for the most focused image. Parallel to the wall will make for a more bass heavy sound and proportionally more reflected vs direct sound.Headphones and IEMs don't do soundstage justice. Floor standing speakers wide apart and parallel to the wall is your benchmark. A fair amount of headphones have good imaging capabilities.
I'm making a recommendation for sound stage. It doesn't have to equal what's good for general listening or what I personally use.Why do you suggest parallel to the wall? I would have suggested speakers pointed directly at the listening position for the most focused image. Parallel to the wall will make for a more bass heavy sound and proportionally more reflected vs direct sound.
