MouseOnMars
- Joined
- Jul 10, 2026
- Messages
- 76
- Likes
- 62
- Thread Starter
- #41
Yeah, if you blocked posts in Vivaldi on android, then all those posts should show up in Vivaldi on windows too.fyi, when I enabled the extension on Vivaldi/Win-11 the extension attributes are visible, but it doesn't appear to have retrieved the ID's from cloud storage? I presume they should show up here?
I can't try this since I don't have a windows machine, but grok said this is a common problem and broke all the problems up into five different groups. Here is the first group of five:
1. Basic checks (do these first)
- Confirm you’re logged into the same Vivaldi account on both devices and that Sync is actually started/active (not just logged in). On both platforms go to Settings > Sync and ensure it shows as running/active with the desired data types enabled (bookmarks, passwords, notes, tabs, etc.).
- Update Vivaldi on both Android and Windows to the latest stable versions.
- Check vivaldistatus.com for any Sync outages.
- Log out of Sync on all devices, restart the browsers/apps, then log back in and start Sync again. This alone fixes many cases.
