NPYou are truly a saint. Bless you.
Though again, I was just answering the question, 'who uses Chrome?'
The ultimate would be to store the per-user ID's in the cloud for cross device sync. Export/import could possibly be a manual option?
Sorry to digress the thread subject but out of curiosity - what are you using? Mullvad?And several billionaires to make more $ from you with AI and track small innovative competitive enterprise to consume so we can have even more consolidation.![]()
Just Firefox with ETP add on. Not that worried, I just don't like Google's approach and do not do social media at all. Involved with local charity groups and fund raising for causes, food banks, environmental, land and landmark conservation and get plenty of company.Sorry to digress the thread subject but out of curiosity - what are you using? Mullvad?
you're definitely going to stop them lolAnd several billionaires to make more $ from you with AI and track small innovative competitive enterprise to consume so we can have even more consolidation.![]()
I'm not sure what you mean by zombie threads? Threads you can't block? Or unblock?I am currently having issues with (multiple/many) zombie threads. Should we need to reinitialize after the v1 0.3 update?
Note: browser Vivaldi/chromium
Blocked threads aren't sticking. Block retention was working with this browser when there were only device specific (ie local) ID cache.I'm not sure what you mean by zombie threads? Threads you can't block? Or unblock
The extension version must be at 1.0.3, or you could have issues like you are describing.Blocked threads aren't sticking. Block retention was working with this browser when there were only device specific (ie local) ID cache.
Is there a way to display the extension version? Opening the extension dialog doesn't show a version number afaik.
I am unable to reproduce the problem in v1.0.3 using Vivaldi browser. The simplest thing to try now is to uninstall and reinstall the extension, but you will lose the list of posts you blocked. If you want to try to preserve your block list, please post the contents of your sync storage by following these steps:Looks like I'm already at v1.0.3 but still no joy. Perhaps the new code is working different under non-chrome browsers?
if that turns out to be the case perhaps there could be a per-setting for cloud store vs local store? Otherwise as a non-chrome user I'm out of luck. Thanks.
This presumes desktop, correct? ie not Android.
- Click on the Managed Blocked Posts button
- The blocked posts page should open in a new tab
- Right click on the blocked posts page then Developer Tools > Inspect
ahhh, I think you identified the problem. I didn't realize anyone would try it on a phone since Chrome extensions (at least in the Chrome browser) don't work on phones. All the testing and development has been on my Macbook Air, and Vivaldi works fine there. It's possible some browser/phone combinations will support ForumEQ. I just don't have the bandwidth or hardware to target and test those platforms.Vivaldi Android or Vivaldi desktop?
I think the supported browsers needs a footnote.
Brave/Android doesn't support chrome extensions, yet. Edge/Android supports a limited set, but ForumEQ doesn't appear to be one of them.
So, if those browsers have been tested as working it must be the desktop versions?
I'm wondering if that could be the case with Vivaldi/Android? Scroll works; block dot is there and removes the thread from display. But, when the page refreshes the thread comes back (for me). Again, this is on Android. I can test Windows desktop later.
I'll try your PD asap.
You're right. We're hitting a maximum entry size for sync storage that local storage didn’t have. I’ve just finished rewriting the memory management system to work around that restriction. We’re now only limited by the overall 100KB sync storage quota.After more testing it appears Vivaldi/Android is actually working....up to a point. Once the ID list gets to around 10 or so it starts forgetting ID's. The ID's appear on the list but are ignored for some reason.
Any ideas on what could be capping this?
