One of my iLoud MTM stopped working.
Took it apart to see if an internal fuse broke.
Could not find anything nor any broken parts.
Powered the PCB outside of the cabinet... seemed to work.
Put it back together and switched it on... worked O.K. ... for about a minute or so then switched off again.
Opened it up, removed the PCB and powered it. Sure enough after about a minute it switched off again.
So.. I powered the amp with a lab supply 24V and 12V and it worked fine, no unexpected currents.
There were 2 internal voltage rails 12V (43mA draw) and the main supply voltage (24V / 0.13A idle).
It looks like the power was shut down by the micro-controller for no apparent reason.
Fixed it by mounting a 24V to 12V 1W DC/DC converter (a 7812 would get too hot) to feed the 12V from 24V and made a 24V DC input port on the back and feed it with an external 24V DC brick I had lying around.
So... while I was quite happy with, and recommended the iLoud MTM, I do not do so anymore because of longevity issues (2,5 years is a bit short).
Hoping the newer (and more expensive) MTM has much better longevity.
