I bought one untested and posted some measurements referencing low noise in another thread. I am keeping it!
Link to thread and below and a copy/paste from the thread.
Post in thread 'I can't tell a difference between 4 phono preamps'
https://audiosciencereview.com/foru...ce-between-4-phono-preamps.30363/post-1132801
I got a chance to do some spectrum measurements at the right channel with my iPhone right at the output of the midrange driver of my Grand Veena loudspeakers. Midrange is direct connected - no crossover and runs full range. These measurements are relative only and may not be calibrated. As such they serve to show noise floor differences only at the loudspeaker. Slide 4 Luxman volume was reduced by 6 db to compensate for the additional 6 db of gain in the Zen balance output mode. By the way I checked typical loud playback volume at my listening position with 75 to 80 db peaks with the balanced output and that was around -42 db on the Luxmen - considerably less than the volume used for hearing background noise with no music playing. As you can see from the last slide Phonomena not nearly as quiet as the Zen with the Zen doing best with the balanced output.
Hopefully Amir will get one of these to test to see how it stacks against the other phono stages previously tested.
