somebodyelse
- Joined
- Dec 5, 2018
- Messages
- 6,276
- Likes
- 6,119
Thanks much for a couple suggestions. I’m disabled and on a fixed income so the price of the Spartan 15 at $ 670.00 plus shipping which most likely makes it around $ 700.00 is pushing it for me. Both the Alvo Duo and the IFi are on the order of hundreds of dollar less and have been reviewed by Amir. The Ifi has a subsonic filter as well. I don’t see the Sparton being reviewed by him as well. I might be wrong though.
It’s sort of between those two but if there’s something comparable? Around $450.00 or even $ 500.00 I’d be interested. In the meantime I’m going to closely look those two over again.
Has anyone purchased either of these two? Thoughts? Comments?
Thanks for responding in Advance!
I use the Waxwing's digital optical output into my Schit Modius DAC - which has balanced outputs....Bob, thanks so much for your response. That definitely leans me towards the Zen. Especially since I have a balanced input on my preamp. Thanks to everyone who has responded. Much appreciated and this has given me some valuable info.
That sounds like an incredible system. I recently got back into albums. I had a pair of Sonus Faber loudspeakers “can’t remember the model, their floor standing”, a Rega Planner 3 with a Sony MC Cartridge that I had in storage, a Sony ES Preamp and amp. “I used to work for Sony”. I sold my place and moved into an apartment so gave it all to my Daughter. Now I’m slowly rebuilding my system with an eye to being in a smaller space. I’m going through my records and starting to enjoy them. I just purchased a Korg DS-DAC 10R second hand and am digitizing my cassettes and might do the albums after I purchase a preamp. I’ve purchased the ELAC Debut DBR-62 speakers with a sub and am amazed at the sound. These little speakers sound very nice. i looked at your Waxwing. What an amazing product! thanks again for your suggestion Bob.I use the Waxwing's digital optical output into my Schit Modius DAC - which has balanced outputs....
One thing that really surprised me…the amount of albums on sale now!
MC low at 60 db gain is correct for a 0.4 mv cartridges. I have the original Zen Phono and never noticed a noise issue with MC cartridges on that setting. Possibly something wrong with your unit or some kind of switching noise loop in your setup.Hi,
I'm having a bit of trouble setting with the Ifi zen phono 3.
I have a technics sl-100c with the Oc9xml, so I set the ifi to MC LOW, 100ohms.
With this setting, I have background noise and the gain is too high.
With the MC High setting, I don't have this background noise, but it's not the most appropriate setting.
I made a rip with the Motu m2 with the gain at minimum.
I can provide the audio if it's authorized.
I have the same background noise problem with the original Ifi.MC low at 60 db gain is correct for a 0.4 mv cartridges. I have the original Zen Phono and never noticed a noise issue with MC cartridges on that setting. Possibly something wrong with your unit or some kind of switching noise loop in your setup.
What does +0.14 db translate to in terms of voltage peaks? Can you hear a problem when playing back music? 60 db with a 0.4 mv cartridge yields 400 mv - which should not be a problem. If you use the balanced output - you get 66db or about 800 mv. You could use MC High at 48 db and balanced out for 54 db to get something in between.I have the same background noise problem with the original Ifi.
I think 60db is too much, because as my screenshot shows, there are "true peak levels" at +0.14db.
Oh thanks, it's because I was using the balanced cable that my gain was slightly too high! Now I have to fix the ground noise problem.What does +0.14 db translate to in terms of voltage peaks? Can you hear a problem when playing back music? 60 db with a 0.4 mv cartridge yields 400 mv - which should not be a problem. If you use the balanced output - you get 66db or about 800 mv. You could use MC High at 48 db and balanced out for 54 db to get something in between.
I use a Waxwing now - which is very adjustable and may give you what you may require. I keep the iFi for a backup.
great cartridge ... great performance / price ratio ... a definitive cartridge for 99% of the peopleAudio-Technica VM540ML cartridge.
I am thinking about the Zen 3 vs Rega MK5 to use with Technics SL1500C and AT-VM95ML, wich one would you guys recommend?
The Rega Fono MM Mk3 was measured here <https://www.audiosciencereview.com/...s/rega-fono-mm-mk3-phono-preamp-review.17278/>.There's no Rega preamps measurements here in ASR (i believe), but we got the Zen 3 measurements and is very competent.
So ... short answer? Zen 3
