dtaylo1066
- Joined
- Jan 12, 2019
- Messages
- 657
- Likes
- 822
Like putting two gas filters in a car when you already have a sufficient one.
We gonna have to bring Brian Greene on here to call b.s. on your IFI string theory? Anyone know the ceramics IFI are using are room temperature superconductors which eliminate jitter by directly coupling your DAC to its source. The simplest snake oil explanation is always the best one.So disappointed neither Amir nor ifi itself noted THE MOST crucial aspect of this device: the ceramic case absorbs spurious vibrations induced by oscillating strings at the sub quantum level. The cryogenic process used further helps by aligning the ceramic structure, making its string energy absorption twice as effective. The extra jitter spikes are likely revealed by this filtering and are caused by disharmonious resonance with standard usb plugs of plastic or metal. …to fix those you need to replace the other usb cables with ifi audiophile usb with ceramic plug casings. For maximum clarity, you need to swap the internal chips out with ifi ceramic package chips, using only Cardas silver solder in the reflow process.
Hold on, I am having trouble due to my tongue being so distended into my cheek.
OK, so this thing does slightly more than nothing with poorly designed DACs, but why should it cost even $49, let alone $149?This is a review and detailed measurements of the ifi iPurifier 3 "USB Audio and Data Signal Filter." It is on kind loan from a member and costs US $149.
The iPurifier 3 comes in a gorgeous and nice to feel ceramic (?) enclosure. The enclosure give is enough weight to feel substantial but not too much as to strain the connector. It is an in-line device and comes with three useful adapters which should cover all your USB connection needs.
In case you are wondering what this is for, here are the company specs:
Think of it as a USB repeater of sorts. For the purpose of this review, I take for granted that it does all of the above. Question becomes if our audio DACs need such an upstream device to "clean" their USB connection.
ifi iPurifier3 Measurements
My favorite device for testing USB signal quality is a Schiit Modi 2 which in the past has show very high sensitivity to conditions of that signal. So much so that I could measure differences USB cables make when connecting to it! I started by measuring the DAC by itself using a 6 foot USB cable:
There was a ton of noise in the FFT spectrum with the noise floor jumping up and down every few seconds (no doubt due to activities in my PC). That in turn caused the SINAD to vary continuously between 84 and 91 dB. This variation is system specific and could be worse (or better) on other host computers.
Next I put in the iPurifier3 inline:
There was a significant reduction in the noise floor as show in FFT and power supply related spikes. There were still jumps but much less in amplitude. SINAD was now very stable. So clearly such filtering was good for the Modi 2.
One could stop here and think that this is a useful device. But such is not the case because any DAC with half decent design would isolate itself against USB vagaries. To show that, I grabbed the Schiit Modi 3+ which costs just $99 to test. Here it is by itself:
We see massive decrease in noise floor compared to Modi 2. Predictably, it doesn't need any help from iPurifier3:
I almost stopped here but noticed there was some increased spike toward end of the spectrum. I decided to run the Jitter test with and without iPurifier3:
We see much increased spurious tones at 8 and 16 kHz. This corresponds to a jitter component of 4 kHz (12-4 and 12+4 kHz). I can't directly point to the cause of this but can guess that an extra inline device that uses power like iPurifier3 is going to degrade available current to the DAC. Fortunately the increased jitter rises up to only -120 dB which is below threshold of audibility -- again a sign of well designed product (Modi 3+ DAC).
It seems that the iPurifier does what it says it does: clean up the signal/power lines over USB and with it help devices that need it. Then again every DAC I recommend of which there are probably 50 to 100, already perform their own filtering and don't need any help. After all, I test them all on my desktop workstation without any such filters. Adding an active device to the USB connection can reduce available power and potentially decrease measured performance as show in the case of Schiit Modi 3+. Seeing how a better DAC costs less than iPurifier3 anyway, there is no reason to deploy such a device.
I can't recommend the ifi iPurifier3. Put your money toward a good DAC and sleep easy!
$149 is way up there to be sure. But given the market size, $49 probably doesn't make it worth the effort to create, market and sell.OK, so this thing does slightly more than nothing with poorly designed DACs, but why should it cost even $49, let alone $149?
Please use English only here. Thank you!나 ifi는 매번 느끼지만 쓰레기를 만들어서 , 폐기물 만드는 회사처럼 보입니다. 이런 회사는 없어지면 좋겠네요
I suppose that's right, but it's still crazy that this costs more than many adequate DACs.$149 is way up there to be sure. But given the market size, $49 probably doesn't make it worth the effort to create, market and sell.
And here i was expecting nothing but a bunch of ferrite beads inside. Seems they really went all out and actually repeat the USB signal.
It isn’t BS, it would be if you were a manufacturer /reviewer, but…. unless you compare unsighted ( level matched if necessary) it is just an anecdote.I bought one of these as a non believer with the option to return for free. After A/B testing for weeks the IFI cleaned up the bass and the soundstage became clearer while using a Topping D90. I know this sounds like typical BS but that is what I heard. Using MAC M1>IFI>Topping D90 that has good measurements. I suspect the MAC or the AC is causing issues that the IFI fixes. Also tried it on a Korg DAC that was given a failing test on this site and it improved the sound overall. Thanks for the review.
There was motion!I know this sounds like typical BS but that is what I heard.
nicely said & seriously, this ball is moving..! but not getting anywhereThere was motion!
I know it sounds like typical BS but that is what i saw.
Just consider that our brains are neuronal networks, constantly under pressure to save energy, reduce data and yet detect patterns. They are not instruments. What we hear and what really is there are often different things.
That was tongue-in-cheek.We gonna have to bring Brian Greene on here to call b.s. on your IFI string theory? Anyone know the ceramics IFI are using are room temperature superconductors which eliminate jitter by directly coupling your DAC to its source. The simplest snake oil explanation is always the best one.
Epic post of the night, and very true. CheersThere was motion!
ThanksEpic post of the night, and very true. Cheers
