ifi hip dac review (DAC & Headphone Amp)
charleski
Manchester UK
I cannot for the life of me interpret their measurements. Amir's and Wolf's are so much more simple. I do recognize some of them though.
If I'm interpreting the ones I see correctly, it's not that good.
"With a full-scale 50Hz tone in Solid-State, HiFi mode, the third harmonic was the highest in level at –60dB (0.1%, fig.15), though reducing the level to –3dBFS dropped the level of this harmonic to –67dB (fig.16).
there is still much to admire in its measured performance.—John Atkinson"
:facepalm:
You have to give him points for trying, though, as so few in this industry even do that.
This is a spectacularly bad product, especially given the $2.5k price tag.
DanTheMan
My FiiO A5 died suddenly last night and in my mourning I was hoping this would be the replacement. First loves are impossible to replace. RIP A5. You’ll never be duplicated it seems. I wish I could understand why, when it’s already been done, no one has said “let’s do that again!” JDSLabs or Schiit should get on it. Topping doesn’t seem interested and FiiO has shown the last remaining folks like me the finger.
respice finem
Oops... I thought DACs are commodities this day and age. Even my Musical Fidelity V90-DAC oldie measures better, OK it doesn't have that hip Hires sticker :D
Asylum Seeker
Guatemala
On the chi-fi IEM boards this has been a bit of a darling. I, myself, counseled against it several months ago and recommended the Topping NX4 DSD. No one listened and everyone jumped on the hype train. I am vindicated.
Dr. Schweingruber of Cobalt Blue infamy was a cheerleader of this one too. Seems he likes the sound of broken gear.
Zensō
California
I owned this for a couple of days when it first came out and promptly returned it to Amazon. It’s the only electronic device I’ve ever owned that had clearly audible distortion to the point that I thought my copy was defective. Apparently not.
THW
just a quick glance and I’m already asking: “why tf would I ever get this over a Topping NX4 DSD?”
raif71
I have both ifi hipdac and nx4 dsd. Both sound fine. I got the hipdac coz of the 4.4mm jack hp connection.
Azathoth
Surprised to see that sort of distortion. Then again I probably won't be able to detect it, and the overall sound is going to be affected by whatever headphones it will be used with. It's all just subjective in the end. It looks really cool though, reminds me of my old Fiio Q1.
anphex
Berlin, Germany
I can handle anything. 40db SINAD? No problem, but the sloppy tilted HiRes sticker breaks the deal. This would bother me limitlessly.
Azathoth
I still have my old JDS Labs C5, it has been repaired twice by them, once for the battery once it was dead, and another for a headphone jack replacement. The latter was outside of the warranty and quite recently, and they only wanted me to pay the shipping costs. What a wonderful company. I still use it to this day.
THW
MQA...LOL
In all seriousness, the ifi has more power from the HP output than the Topping one.
well yeah but it’s not like the Topping is a slouch in that department. 52 mW @ 300 ohms is perfectly respectable imho.
DivineCurrent
Thanks for measuring my unit Amir! Yeah I was pretty much expecting this performance, not surprised at all. I have since moved to the E1DA 9038S and 9038D, and couldn't be happier.
AudioSceptic
Northampton, UK
This is a review and detailed measurements of the ifi hip dac combination USB DAC and portable headphone amplifier (with battery). It is on kind loan from a member and costs US $169 from Amazon including Prime shipping.
I don't know why ifi thinks this is a "hip" dac as the enclosure is a generic one offered by others:
Unusual here is inclusion of a balanced, 4.4 mm headphone jack which is nice. A bass boost function is provided which is also not present in other products.
I was surprised that I could not get the unit charged through its standard USB port but had to use USB-C:
As you see ifi continues to use male USB connection so has to provide you an adapter. Have not been a fan of its thick cable even though I understand their motivation.
Ifi Hip DAC Measurements
I started testing in balanced mode. Output was a healthy 6+ volts in high gain so I dialed that down to 4 volt and got this dashboard:
Wow, we are so used to exceptional performance in this class product that this level of distortion really stands out. SINAD of 70 dB lands the hip dac at the bottom of our 330+ DACs tested:
Unbalanced out has a max of 3 volts so I adjusted that to 2 volts and results were the same:
So for here on, I am going to use balanced output adjusted to 4 volts except power tests where it is at max.
Noise level is much more decent than distortion:
The reconstruction filter is both slow and doesn't attenuate enough:
Jitter spikes are not that visible but this may be due to high noise floor:
Linearity is not acceptable in this day and age:
It should be able to easily do 20 bits.
IMD distortion test shows that the output saturates early and allows distortion to rise:
Multitone which is run at lower levels does better as a result (than our dashboard):
Sweeping against frequency shows flat, high distortion:
Key here is power versus distortion into high and low loads. Let's start with 300 ohm:
While distortion rises good bit, there is also a lot of power available which is nice.
In low gain, we don't have a lot of power but do have distortion:
The xBass enhancement goes too high in frequency in what it boosts:
Without xBass activated, response is dead flat to 20 kHz so all the talk about the BurBrown DAC having mellow/laid back sound is nonsense. If anything, its high distortion can make things sound a tiny bit bright.
Finally, channel balance was surprisingly poor:
The sample you get may be different though.
Ifi hip dac Listening Tests
I started with my Drop Ether CX headphones using balanced mode. Here, I could only get to moderate levels beyond which, audible distortion set in especially with bass notes. As a result, turning xBass on severely degraded the sound causing me to listen at very mild volumes. Switching to Sennheiser HD-650, it sounded very good and was able to get quite loud. xBass effect was a bit much but not too bad if used at lower listening levels.
There are a lot of arrows pointing against the ifi hip dac. It doesn't look hip and has a very low performing DAC platform with high distortion. What saves it is that it has a lot of power with high impedance loads using balanced outputs. Even without balanced, it can drive headphones like Sennheiser HD6XX. So if that is your application, it may do. Otherwise, the game has moved on way, way past where ifi is. Company needs to build a new DAC platform to be in the running.
I can't recommend the ifi hip dac.
iFi claims to be the affordable offshoot of a high end/pro audio company, offering high end performance at bargain prices. As such, the hip DAC is a disgrace.
The fact that iFi also sells snake oil products (power "purifiers" and digital "enhancers") is not encouraging. I will continue to stay well clear...
AudioSceptic
Northampton, UK
fwiw, I love my hip dac and how it sounds. I pair it with fiio m6 dap. :)
Connected together by bluetack (in this case whitetack). I use this when I'm doing chores around the house.
So, a portable DAP that needs a separate amp? If you're out and about, do you then have 3 devices (phone + DAP + ifi)?
