IFi Defender +…the polish you need for dirty USB audio!
This works perfectly and has been successfully tested on countless DACs.
For DACs with their own power supply, you only need to disconnect the positive supply voltage; the negative supply voltage is needed to detect the connection.
For a DAC that requires a 5V supply, the positive supply voltage from the host is also disconnected, and the DAC is powered with 5 volts via the Y-cable.
Small circuit boards that accomplish exactly this are also available on AliExpress.
I think this ifi device basically does this. If you look at the inside images, it’s just a bunch of transistors, probably to automatically switch between the supplies.
On the other hand, there are no components?
That would be really disappointing.
If the part costs more than €3-4 to manufacture, that would be ridiculous.
Noise or ground loops via USB are relatively common when using a PC as the source. At least as far as I have seen. You can simply hear it, as soon as the amp/active speaker is on even with no music playing. The noise also often changes if you load the CPU or GPU and sometimes even if you move your mouse. On DACs with a well designed grounding scheme it shouldn't make it to the amp, but sometimes it just does.
Agreed, there is also a notable difference using different power supply's for the Defender itself. I tested 3 power supplies and by far the best outcome i.e. cleanest sound is with the iFi Power X.
Assuming the audible differences are nearly as significant as you describe, then you're only treating the symptoms.
If you actually achieve an audible improvement with such simple means, then it's safe to assume that some of the information was already lost or severely degraded beforehand.
It's physically impossible to recover lost information, and you can't improve a digital music signal.
Perhaps it would be more sensible to invest the money in a technically sound and properly functioning source rather than in essentially useless accessories.
By far the most effective device for USB problems is the Intona USB 2.0 Isolator. This device was developed for industrial, measurement, and medical technology applications and is also used in the development and measurement of professional audio equipment, including, as far as I know, by RME.
In a technically sound hi-fi system with a USB source, the Intona USB Isolator is completely useless and offers no advantage, neither audible nor measurable.
Perhaps you should buy one of those and only return it if it doesn't make an audible difference in your system.
IMHO that isolator was developed (and priced) way before single-chip USB2 highspeed isolators from TI and Analog Devices hit the market. Today the price of high-speed isolators has dropped to below 40USD from China. Yes, they are still very useful.
That's correct, but unfortunately, none of these inexpensive USB isolators can compete with those from Intona.
We use the Intona ourselves for measurements of our industrial products. I also thought that the newer, inexpensive USB isolators would work just as well, and ordered three different ones, including one of the ones recommended here. But the difference is truly night and day (not in terms of sound quality, but in industrial applications), and crashes during our measurements were unfortunately the result.
The devices do work in principle, but unfortunately not always adequately. There are also cases here in the forum where galvanic isolation of the USB connection via an inexpensive DDC and a Toslink connection to the DAC worked perfectly, but one of the inexpensive USB isolators didn't solve the problem satisfactorily.
I've lent out the Intona countless times over the past few years, and it has always functioned flawlessly.
From my experience in medical technology, I know that even more expensive competitor products don't always work perfectly, unlike the Intona.
At least, that's been my practical experience.
However, as I said, that's just treating the symptoms. It's always better to solve the underlying problem; then you don't need any of these devices.
Thanks. Is the problem with the actual data transfer, or perhaps inadequate power of the isolated DC/DC power supply, incapable of powering the attached USB device reliably? It would be rather surprising if TI and Analog Devices designed a faulty chip. The DC/DC functionality is unrelated to the actual isolator chip.
The problem isn't the power being transmitted, but likely the DC/DC filtering and digital transmission. However, this also depends on the specific problems and the application.
I know of cases where one of the well-known wall wart filters from the DIY forum produced perfect results (connected directly to the computer's +/- power supply of the USB output), but also cases where complete galvanic isolation via Toslink was necessary.
I wonder if it was the built-in DC/DC PSU, and using a standalone 5V PSU for the device would have fixed the problem. I would be really surprised if those new chips were having issues with USB2 highspeed when that is their only purpose.
It's not about speed issues.
In the case at hand, disconnecting the positive supply with an external power supply would likely have had the same result.
But again, there are several potential problems.
The two basic chip solutions from TI and ADI naturally have limited functionality and were developed as inexpensive standard applications. Of course, the implementation of the ICs and the DC/DC filtering are also crucial.
Therefore, there will likely be differences between the various implementations.
The Intona is a very sophisticated bidirectional isolator/reclocker/repacketizer at the physical level, which has been used for over 11 years in all areas of industry, medical technology, science/research, aviation, etc., and must function without any limitations. It also has a protection function, as devices with 4, 5, or 6 digits are often connected.
The firmware is also customizable if needed, and Intona has a head start of about 15 years in this area.
You would have to delve deeper into the subject, take your own measurements, and analyze the various different cases.
But what's the point if you can avoid these cases altogether?
Used Mac Minis and HP business desktops and notebooks in good condition can be found for €150-250. I've never had any USB problems with audio using these, and the use of an Intona USB isolator (or any other) is completely useless.
I have an Lenovo M920q PC. This little 1 Litre box of wires ‘n’ bits is my primary music server. It’s quite a cost effective solution. It is not the most quite or cleanest motherboard made and many have noted this with the Lenovo PC. In short the USB on this thing is dirty, noisy also impossible to dumb the power down but that is another issue.
I run an usb cable to the Douk Audio U2 Pro (2025) and optical to the dac. I ran coaxial to the dac but static crackle soon killed that idea.
The sound was clean, not run home and tell your mum impressive, but clean enough. In consideration of nullifying the static via the coaxial connection from the U2 to the dac I decided to grab an iFi defender + when I saw one at a very reasonable price. I had no idea what this thing would do realtime and only had theory based on what it supposed to do.
The iFi Defender arrived today and after some fiddling around got the thing pushed into place and the U2 Pro plugged in. I am using a cheap GaN 5v power supply from Amazon to power the Defender.
Everything a place and into Apple Music to pay a few select tracks with desired frequency highlights.
What a difference!
Big clean up operation complete and in one little device! Just how dirty the usb power delivery straight from the PC to the U2 is now clearly evident by just how effective the iFi Defender + performs. It cuts off the power from the usb that was feeding the U2 Pro and with the power supply plugged into the Defender now feeds the U2 Pro with that power.
The difference is literal night and day. The bass is much cleaner and more precise without all that dirty noise coming from the motherboard. The vocals have lifelike clarity and the high etc and all clean, clean, clean!
This is a significant upgrade to any PC based system imo and not just for ground looping, hum etc but also just for dirty usb!
I would recommend this little gadget to anyone using a PC and usb as their audio source without any hesitation. I don’t work for ifi or am sponsored to say this. This is purely my own equipment and experience and I have to say iFi, top job boys and girls!
*blows whistle* Flag on the play.
Improper use of "literal." 20 yard penalty. Repeat 1st down.
It does not change the time of day, it is not literally night and day, it is metaphorically night and day, but you don't have to say "metaphorically night and day," we already know "night and day" is a metaphor not to be taken literally.
If you're after true galvanic isolation, then for the same price as the iDefender you can buy proper USB isolators like one of these:
Topping HS01
Topping HS02
Hifime High-Speed USB Isolator v2
JDS Synapse
Neutron HiFi Isolator V1
DSD TECH SH-G01L
Olimex USB-ISO-HS
NVarcher also sell one on AliExpress.
So yeah, identical functionality at a tenth of the price, or vastly superior functionality at the same price.
iFi's tweaks like the iDefender remain exceptionally poor value.
If I hear no ground loop hum or buzz when I hook up my laptop to my DAC over USB to stream from Qobuz do I need one of these things?
I had a long time audio engineer recommend IFI power supplies and filters. He recommended starting with the modem and router. Adding a IFi power supply to each. Then an IFi Ethernet filter after the modem and where the Ethernet goes in to the streamer.
He said the best way to kill noise is at the source before it ever gets in your systrm.
He recommended the iFi power supplies that cost $319 on Amazon. That would be $650 for just the power supplies on the modem and router.
Instead I have the iFi I power 2. That sell for $79 on Amazon on the modem and router and a single IFi ethernet filter after the router
I am a Tube amp guy and have a good system So I need the help. I added them gradually over an about a month. I wasn’t sure if I heard anything after installing the first power supply to the router I addd the filter then te other power supply and filter over the next few weeks Figuring it couldn’t hurt. It might be doing something I haven’t just locked up on yet
I mostly just forgot about it I wasn’t sure if it did anything. Then one day it was a oh wow I never noticed that moment The blackness of the backgfoumd, the separation of the noted I could hear more detail.
I removed the power supplies and filter and used the power supplies proved by the cable company. There was an increase in noise no doubt about it. It’s insidious noise you never noticed it until it’s gone
I have a smaller less expensive solid state system in my bedroom, I have not tried the IFi there I really don’t know of it would be worth it for me. Solid state vs tube and lower resolution speaker. I would no expect nearly as much change.
My background is analog audio, where ground loops can be a significant problem. They can also occur with digital, and the usual symptom is high frequency hash at a low level, like 60, 70 db down or so. Low enough to simply ignore most of the time, but annoying nonetheless. USB, and other connections usually tie the grounds of the components together, so the solution is to break the ground connection.
I haven't tried it, but clipping the ground wire will probably work. I've had success with the JDS Synapse isolator, or for really stubborn analog domain grounding issues, the RDL AV-HK1. YMMV.
I'm sorry, but that's just money down the drain. The main source of noise in a PC-based system is the components in the PC (mainly switching MOSFETS supplying the GPU and CPU). Adding filters, "upgraded PSUs" and all that other snake oil at any point of the chain before the PC is absolutely useless. The noise can travel via the ground plane to your DAC, which is where you can eliminate it either essentially for free by going the optical route (Toslink from PC to DAC) or by using a USB isolator for <100$ like the one recommended by @Mr. Swordfish.
The noise comes from the system, so: No.
Ethernet connections are galvanically isolated by design. Common chips like the G4801DG are in every switch or router. Adding an "ethernet filter" to an already galvanically isolated connection is redundant and a waste of money.
If you have a tube amp, you do not have a good system ;) (sorry, I had to...)
There are cases where ground loops or noise from a PC connection can cause audible noise in your speakers or headphones. For those cases, the easiest solution is almost always to switch to a Toslink connection between your PC and the DAC, as suggested above. If that isn't possible or would require expensive new devices, a true galvanic USB isolator is a good bet. For all other problems, hunting down the ground loop between your devices is usually the cheapest solution to hum/noise. Sometimes, there are also odd problems like LED bulbs without proper filtering causing noises elsewhere, but those are luckily rare.
Of each of the components that you would power with such PSU, you could potentially just buy an alternative product that is noise free in the first place for less than the cost of the PSU, and keep some money on de side for some nice music.
Oh yeah IFI recommends about 100 hours burn in time to reach their full potential. The audio engineer said it took him about 200 hours to reach their full potential. But he has a very high resolution system.
You're really rattling off all the fraudulent snake oil HiFi vendors' greates hits for embezzling money from their naïve customers :D
Functionless power filters, vastly overpriced PSUs, Ethernet treatments, burning in solid-state components that don't burn it, all that's missing really are cable risers, super tweeters, wooden grounding boxes, and some phase field stickers to stick onto every capacitor and your system will be the epitome of "I got fooled out of my money and am proud of it!"
Uhuh…
Would the “audio engineer “ be so kind to explain the physical mechanics at work here that makes it sound better over the course of 200 hours?
