MattHooper
- Joined
- Jan 27, 2019
- Messages
- 11,620
- Likes
- 20,856
Hard to imagine if your amps are and speakers are working properly. I have old tube amps (MC-30 for instance), and I don't perceive any difference as they warm up. I don't have any gear that changes sound like you describe.
Regarding the mic. If you have a computer and $30 spare dollars, you could get a Dayton mic and answer your question. $100 for a UMIK-1. The $30 Dayton would answer this question in 20 mins... No way any of us can answer though, unless we came over to your place with a mic! And, if you suspect your amp is misbehaving (it is after all 20 years old, and it's tube, etc...), you could set up the mic to a laptop, open up REW, do a sweep, crank tunes for 20 mins, do another sweep, compare. You would learn so much about your system. You would also get huge support from the ASR community, as well as the usual odd comments from people like me!And you would answer this question, and move on to better things. I actually don't enjoy measuring, it is tedious. I am motivated by the result. My enjoyment or not of the measurement totally beside the point. I say because this is ASR and you do post lots of questions that beg a simple measurement. And, we never quite get to a solution. You could just get your answer with a cheap mic.
It could be worn out tweeters. I don't know how old your speakers are, but old ferro-fluid tweeters can age (for instance). I don't think this is your case, but I did wear out a pair of the same Seas Excel tweeters you have in your Joseph Audio, but with a lower crossover than they use... A mic would tell you if the tweeters were (for instance) heating up, or you had a crossover component degraded, etc.
I think it's likely perception. Especially if you tend to adjust volume as you listen. If I make a significant volume adjustment, I perceive for a bit of time a new tonal balance which I believe is Fletcher-Munson combined with our mutable perception of hearing. It could be tinnitus.
This is the era of easily available measurement. And you are a member of one of the only measurement-based communities on the web. We also talk about hearing and perception all the time here so you probably already know we can't provide much help with a problem where perception and sound reproduction intersect. You have some interesting classic gear that naturally seems to cause you to question, and has even given you some odd results.
Thanks very much for your detailed response!
You have a good point about the measuring. I'll re-visit this info if I feel that there's something sounding not right or impinging on my enjoying the system. Then perhaps it will be best to trace it down with measurements. Over the years any issues have been very rare, and when something has popped up I drop the amps down to a local electronics place who restore and fix old gear. If there's an issue they fix it. (But I think the only things have been a fuse going, a tube dying...)
