mhardy6647
- Joined
- Dec 12, 2019
- Messages
- 11,393
- Likes
- 24,706
It doesn't just start off with nonsenseThat article starts off with nonsense.
Well you would think that someone with 50 years of experience in audio knows what they are writing about. But since I'm not a subject expert I would appreciate if you could point all the nonsense so I can email the author.It doesn't just start off with nonsense
I more meant that the entire premise of the article is nonsense.It doesn't just start off with nonsense
Care to elaborate?I more meant that the entire premise of the article is nonsense.
So are there in fact practical (e.g., commercially available) amplifiers (ss) with identically zero output impedance? This would represent infinite damping factot Damping factor is the ratio of load to source impedance: 100% damping factor is, at best, a misnomer. At worst, it suggests the author has no idea what damping factor means.Regardless of how much Negative feedback is applied it is not possible for a valve amp to achieve a Zero output Impedance (100% damping factor) similar to a solid-state amp.
Long experience does not guarantee understanding IME.Well you would think that someone with 50 years of experience in audio knows what they are writing about. But since I'm not a subject expert I would appreciate if you could point all the nonsense so I can email the author.
When I went through training to become a helicopter mechanic, some of the trainers had similarly bizarre ideas. After they invited me to the front of the class a couple times for algebra and physics lessons, everyone in the class pretty much agreed their explanations were better suited to the audience because they were accessible, though admittedly fantastic. I earned the nickname 'molecular structure' from the boss.Long experience does not guarantee understanding IME.
I have worked with people who have observed what happens in our field (motor racing) and attributed completely technically non-sequitur explanations to why. It tends to depend on early schooling and depth of physics understanding.
Not only that but some, one of the best designers I know, who was trained as a mechanic, had completely bizarre ideas about how some stuff actually worked, so some ideas he came up with were brilliant and some did not work at all.
Some of the beliefs are real moments but confidently held and defended.
Is the core assumption of Valve amps supplying the full power regardless of speaker changing impedance incorrect?
(EDIT -- oops I read correct but you 'said' incorrect)Thank you for all the links. I'm always keen to learn. I think that this article is not aimed towards engineers and is trying to explain the difference between both amps in a way that a layman like myself can understand.
My question is:
Is the core assumption of Valve amps supplying the full power regardless of speaker changing impedance incorrect? As that's the core difference that I got?
Agree. My main tube amp synergizes with my vintage Klipsch speakers and not with my Focal Aria 948s. In other words, the amp breaks down and cannot perform properly with the impedance of the Focals, but functions properly with the Klipsch speakers.(EDIT -- oops I read correct but you 'said' incorrect)
Yes, it is incorrect -- although the use of a transformer to couple the high impedance of the power output tube's plate to the low impedance of a loudspeaker load helps a lot in that regard -- which is why McIntosh uses autoformers (which function like a transformer, albeit without DC isolation) to this day in some of their solid state amplifiers.
Transformers and autoformers are amazing things, but they are imperfect (if nearly magical!) electromagnetic devices. As a consequence, designing and constructing one that has broad, flat bandwidth and can handle reasonable amounts of power across that bandwidth is 1) nontrivial and 2) not inexpensive. They have largely fallen out of favor for impedance coupling (especially in the audio power amplifier output stage) due to the inevitable compromises they present and due to the cost and weight that they add to a power amplifier.
In fact, the high output impedance (low damping factor) of a vacuum tube amp is why they are very sensitive indeed to the impedance curve of the loudspeakers one uses with any given vacuum tube amplifier. Much of the vaunted "system synergy" (and, shall we say, reverse synergy) arises from this, I think. The output impedance and "flat" frequency bandwidth of a vacuum tube amplifier can indeed be improved by judicious use of negative feedback -- so, there's really no good reason to fear or berate the application of NFB in any amplifier, as long as it's employed correctly!
The short answer is no. A solid state amplifier delivers more power with decreasing impedance up to a point.Sorry I meant correct and the whole thing went very meta.
Ok so to make things clear: will a valve amp in ultra linear mode or tetrode configuration (I think it's what author mentioned) supply more power to the speaker in line with its raising impedance? Is it any different to a solid state without autoformers like for example my Sony av receiver? I'm here to learn. Thanks for your replies so far.
No. Simply put, the power delivered into a purely resistive load from a transformer-coupled audio power amp will not vary from tap to tap.Sorry I meant correct and the whole thing went very meta.
