I read on the Internet that output transformers suck and are old technology so Mcintosh sucks towhich is why McIntosh uses an output transformer on all amps, tube and SS...
Feedback is feedback, no matter if it is a tube amp or a solid state amp. Exactly the same purpose, exactly the same effect. So not sure about your point.
To destroy damping factor and frequency response, and to cause distortion?
“But you can’t hear that difference unless you peek. Because right versus left brain.” Maybe there’s alpha waves involved.to Quote from Nelson Pass..
What we found is that with high level of feedback, the overall
distortion is indeed lower vs. with no feedback. But what
is interesting is that although feedback has lower distortion,
there are higher harmonics of distortion that occur in peaks.
These peaks are narrow so they don't add up much to the
overall distortion, but I guess that's why high feedback
amplifier usually sound less musical vs. no feedback amp.
It keeps a constant impedence load on the amp and therefore the amp puts out a constant single power level versus the variable levels of amps without them
Lazy designs are lazy, whether they manifest or not.
The last part of that statement ("high feedback amplifiers usually sound less musical vs. no feedback amplifiers") is based on what exactly (other than sighted subjective impressions)?
The rest of the statement is also dubious; see here for an explanation of why.
Are you calling feedback designs lazy? I'm confused![]()
That would be between you and Nelson Pass... I'm merely the messenger. I have heard the same from other sources however.
I think it comes from "it sounds different, it is very expensive and a guru tells us it is better"That would be between you and Nelson Pass... I'm merely the messenger. I have heard the same from other sources however.
I do think it comes down to "measurements" vs tone ... one measures well the other sounds "well" ..
in a solid state amp, yes.. (not really me, as I'm not an amp designer) but Nelson Pass... who is.
what makes said guru any less guru than anyone else (here or elsewhere) .. ?
Let's make it between Bruno Putzeys and Nelson pass then, hey?![]()
