Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
The file is riped from CD and read by MusicBee from a computer.
Either by USB or Bluetooth. The sound is the same.
The merchant https://portier-hifi.ch/ from whom I ordered the device also made the same observation as me but also on other products.
Look this is not some mysterious thing. The signal coming from the device is all there is. It either is exactly the same, which it will be if the same bits are fed thru the same device or something is different in the feed or in the output after conversion between direct CD and streaming. If you don't verify those, reasonably easy if you have the tools, then it quite frankly is crazy to go on about how the same bits sound different.
As others have mentioned, the output from the CD player is likely a little bit louder than the streamer which makes the sound perceived as slightly fuller.
What you are describing is just about how it will sound if one is very slightly louder. Like a half db or something. You won't notice it sounding louder, but it will sound/feel like a quality difference.
If you cannot check and guarantee matched levels, you aren't getting past job #1 in comparisons.
"If you cannot check and guarantee matched levels, you aren't getting past job #1 in comparisons."
Okay, if you say so.
To be very specific, the files sound like a CD read by a REGA Apollo.
Player which I was really very disappointed with despite the glowing reviews from many "great" specialists.
You seem determined to pretty much ignore the input from everyone here, so I'm not sure it makes sense to keep this going.
If you decide you want to move this discussion forward by actually doing something more than make more unsupported claims, please let me know directly and I'll open this thread back up to you.
1) Rip the CD a second time and compare the files. This looks for errors in the ripping process. A lot of people use “Exact Audio Copy” since some other software doesn’t have the normal error correction or specialized modes.
2) Bluetooth shouldn’t sound the same because it’s lossy. This suggests a different path.
3) My experience with the Sony TA-ZH1ES is that different file formats which have the same perceived dBFS in editing software are reproduced differently at the analog stage. The same hardware may have different output levels for the same digital dBFS for disc versus file. See my post on the DSD sound of Japanese drums.
What I'm trying to say is not a question of level or bandwidth. It's more about the feeling of "fullness" of sound.
I would say it's like distinguishing between the timbre and the bandwidth of an instrument, they are two different perceptions.
TL;DR perception of frequencies varies depending on SPL, so a small change in SPL can be perceived as a change in tonality instead of a change in SPL. Also why music sounds better when you turn it up.
No, he specifically said “with the Cary”. That implies that the device does it. But once again, a total lack of any details to properly assess the situation. By now we’ve identified more than half a dozen things that could cause a possible difference…
If the upsampling is the cause here, it should be easy to check: you can just disable it. And if you hear a difference it’s probably because the digital filters of the Cary are terrible and/or the upsampling changes the volume slightly.
Contrary to what the manual claims about evil up/oversampling in DAC chips, the AKM chips in this thing happily oversample at 128x and 256x
I’m pretty sure that there are close to zero DAC chips that upsample to only a fixed rate of 96 kHz.
