If a passive RCA splitter has an unused output, does it degrade quality?
olds1959special
Los Angeles, CA
Apparently it does but I can build something with a "terminating resistor" to fix this? Can anyone help me with this?
AI:
Yes, a passive RCA splitter can degrade quality with an unused output, though it may be unnoticeable. Leaving an output open can cause signal reflections and affect the signal on the used output, particularly with sensitive equipment or high frequencies. For the best results, use a splitter with all ports connected or a quality splitter that can handle the load.
How it affects quality
  • Signal reflection: When an output is left open, the signal can reflect back, disturbing the signal on the connected output.
  • Impedance mismatch: An open port creates an impedance mismatch that can cause issues like distortion, although this is often subtle.
  • Frequency loss: Cheap or poorly designed splitters can have higher capacitance, which can roll off high frequencies.
How to minimize degradation
  • Connect all outputs: If you can't use both outputs, you may need to plug a terminating resistor into the unused port to properly match the impedance.
  • Use quality splitters: A well-designed passive splitter with the correct impedance will minimize signal loss.
  • Consider an active (powered) splitter: An active splitter uses its own circuitry to boost the signal and can compensate for signal loss, but these are more expensive and less common for home use. "
Don't believe AI. :P
Remember, we are NOT impedance matching and at some point you'll have too many parallel loads.
So if I have an unused output, I shouldn't worry? I don't need a splitter with less outputs?
AI:
You do need to terminate open connections IF you are operating at RADIO FREQUENCIES
(or running an 10Base2 ethernet network).
Apparently it does
No it doesn't.
Regardless what any AI has compiled from the web which includes a lot of nonsense and not applicable info (RF) which the AI cannot separate from facts concerning audio.
Why does anybody bother with anything that AI comes up with? These sort of answers shows that not only AI has no intelligence, but that it has no understanding of technical matters, just regurgitates training material with no understanding.
AI may be great for specific tasks, like pattern recognition in large data sets, but for answering consumer issues, it's utterly useless.
Some academics I know despair at the utter tripe some students turn in as work which they got from AI. Might as well ask The Flat Earth Society about geography.
S
AI is dumb sometimes.
For these purposes, the effort to get a good answer from an AI and then fact checking it with your own knowledge is so high, it's easier to learn about this stuff yourself in the first place.
It's either 1) you don't know enough to see its inevitable, frequent, blatant errors, then it's misleading and detrimental to your effort.
Or 2) you know enough to judge that accurately, then it's superfluous.
Or 2a) like @WXfreak above: you know the correct answer in advance, and that is why you find just the right questions to get it. :D
To OP, I'd argue your statements are accurate but only if you are in the MHz / GHz (or higher) range. At audio frequencies the reflected signal from an impedance mismatch is inconsequential and nearly immeasurable due to the very long wavelength of audio signals. I've worked with variable phase combiners on satellite communication systems and phase issues due to impedance variances were only a concern above L-Band RF. Just my $0.02 FWIW.
AI:
This is nonsense - total nonsense. Especially the stuff about connecting unused outputs, and reflections and impedance mismatch (for audio frequencies) - good grief.
Also - please comply with the forum policy to clearly label AI content, and provide the prompt used :
Agreed! It's like bouncing ideas off my coworker, who is just as dumb as I am. :D
It's more like, you're the smart one, want to convince a stupid, stubborn colleague of something, and then come up with questions specifically designed to guide him into the right direction and make it seem like he came up with it himself. :D
I might suggest that colleague is more likely your manager, boss or the idiot in charge.
