IEMS that will fit a Galaxy buds 2 owner?!
ItchyPong
Hi I've recently discovered the world of iems and bought some 7hz crinacle Xero 2s.
I'm having issues with sealing them and have tried a few ear tips and but I'm getting a tinny sound. If I hold them in a bit they sound amazing but when I let go..... It returns to a very thin sound.
I'm wondering does anyone use galaxy buds 2????
As these fit my ears perfectly and if so what iems fit them as well as the galaxy buds?
Any help would be gratefully received!!
I'm so close to falling in love with cheap iems if I can just get a pair that fit 100%
I don't know, I've had the Buds 2 (now replaced with Buds FE after the left bud stopped charging) and they fit me well, but so do Zero 2.
Maybe you need something with a longer nozzles or just smaller?
I'd try the Chu 2, there's Truthear Gate or Hexa (not that cheap, though).
If you read the Zero 2 thread, people mention other tips they used so you could try getting those. But the cost of all those tips might add up to more than differently shaped IEMs so it's a hard choice
My strong advice is to buy a set of the biggest memory foam tips you can find that fit the IEM. We sold a set of IEMs at my previous job and foam tips fixed 80% of customer complaints, be they about sound, comfort, etc.
+1 on the foam tips, they're cheap and usually improve the fit.
I speculate that they can also reduce the intensity of the ear-canal resonance since some energy could be absorbed by the foam - but I'm no acoustics expert so that can be false.
