Bernard23
- Joined
- Nov 25, 2020
- Messages
- 960
- Likes
- 727
What I meant was that you can't compare speaker measurement and the associated correlation to perceived quality to headphones because of the different way the sound is delivered into the ear canal, ie HRTF. Agreed that Harman isn't a neutral curve, it's a statistically determined preference curve.Effects of the pinna? Not following you on that one.
Many don't like the sound of KEF, Genelec and Neumann, because they are very neutral. Many does like them for that exact reason. By creating a baseline of neutrality, one can speak about bright or dark in a conform way, which make it easier to understand what one is buying.
If you read this article (https://headphones.com/blogs/features/the-shape-of-iems-to-come) you will se that a Harman curve is not flat/neutral. Even less so on IEMs.
FWIW this clip by Joel explaining how the JM1 or Meta target was developed is interesting, it focuses on the measurement challenge rather than the validity of the end result, which given the uncertainty around an individual HRTF makes sense as a baseline.
