iem similar to dt1990 pro?
s002wjh
does anyone know a IEM have similar sound as dt 1990 pro? i mainly listen to vocal
there is none. but basically you want a mid treble present IEM and depending on the pads you use, you want bass to be either wooly or taut.
also, budget?
and if you listen to vocals then you want the low mids to lower treble to be controlled and balanced
also, budget?
my budget is sub $400 iem.
i'm using the default pad for 1990 pro. i think its the balanced pad. so its warm-neutral?
not with that mid treble unless your head luckily propagates that treble peak as smooth. I have never had that luck with Beyer headphones
