IEM choice help
JediMa
Italy
I'm trying to find good IEM for a reasonable price that can compete for sound quality with my best Headphones, in order to have portable option to listen music for good. Neutral but with the right amount of bass, excellent detail and good imaging. Budget 100 - 200 max
I suggest you to start with entry level ones to find your preferred tuning and if necessary upgrade later.
I suggest you too start with every level ones to find your preferred thinking and if necessary upgrade later.
I have the ones in my signature, they are good but they don't sound that good, I would like to have something better.
I suggest trying some EQ with what you have to better understand what differences you like to see in another IEM.
Thank you
Looking for a replacement to my Senn CX 6.0BT, that died because of lack of use.
I am not a fan of IEM but I need a pair for some cases.
Need BT (APTX ?) and I prefer the around the neck format for safety, if possible.
Any recommendation within 50-60 Euro budget ? Thanks.
Amir tested an IEM from JBL.
https://www.audiosciencereview.com/...s/jbl-endurance-run-2-wired-iem-review.58635/
There is a different version of that IEM.
https://www.amazon.de/JBL-Endurance...-Freisprechfunktion-Schwarz/dp/B0BVWCYS8M/ref
My old Senn cx6 sound very good, but they were very expensive years ago.
