MattHooper
- Joined
- Jan 27, 2019
- Messages
- 9,591
- Likes
- 15,926
The only reason I initially changed the cable was over time I had moved from some KZ/CCA cheapie dynamic IEM's to the ARTTI T10, which is head and shoulders above these other IEM's in the resolution and frequency response accuracy. Just in another league. No contest.
So now I had a better listening device, the T10, I wanted to revisit the comparison between the TempoTec Sonata BHD DAC dongle, and an Apple USB-C DAC dongle. The only way to equitably compare these DAC dongles, was to use the T10 with an unbalanced cable, rather than the balanced cable which I ordered it with. So I had bought an unbalanced cable for the T10 separately, so I could use the T10 with my digital stage piano, at home, and also use it to monitor when I do live mixes for events. I'm also a musician and audio engineer, both of these as hobbies and also my profession.
So with the T10 and the unbalanced cable, I was able to compare, at a good quality, the TempoTec SOnata BHD, and the Apple USB-C Dac dongle, as well as use theT10 with the headphone outputs of my digital stage piano, and the mixer at my live events - which also have unbalanced outputs.
It was when I now reverted to the balanced cable which had been the de-facto cable which I normally listen to the T10, and the BHD dongle, that it was obvious to me, something is different !, then I spent hours yesterday going back and forth between the balanced and unbalanced cables, which led to me starting this thread, to reach out and understand better what my ears were definitely hearing.
I have spend further time today, swapping between the balanced cable and the unbalanced cable on the T10 and the BHD, and am even more convinced, they do not sound the same. I prefer the balanced output. The unbalanced output sounds like a subwoofer was switched off !!!....anaemic. Still have not figured out why?
But over the next few weeks, as I order, by the grace of God, more cables, headphones and IEM's and maybe another good quality dongle DAC, I'll get to the bottom of the issue, and it will be a huge much needed education. No more theories, and conjecture but will arrive at an exact understanding of what's going on. And can say without a doubt if its the DAC/Headphone Amp, or the IEM's in question - the T10, or the cables that are responsible for this variation, I have observed.
We'll by the grace of God, get to the bottom of all this.
I hope you take the advice here to do a blind test. They can be very educational.
I’ve “ heard” differences between things like expensive AC cables, but when I did a careful blind test between the expensive AC cable and the cheap AC cable that comes with the equipment - when I didn’t know which I was listening to - I was unable to tell any difference. The telltale sonic differences I thought were there simply were not there to help me distinguish between the cables.
I also had similar experiences with video cables back in the analogue days of Home Theatre. Certain expensive cables seemed to make a visual difference until I manage to blind test a range of cables from cheap to very expensive, and once again those
“ differences” disappeared.
It’s one thing to have people tell you about the power of bias. It’s another thing to experience it yourself. Then it becomes a lifelong lesson.
