Feel I should add that would like to keep the focus here on improvement ideas.
Since You ask this way ...
amplitude response does not need finer resolution
- grand total is summed up in- and direct sound, will vary wildly in different setups anyway
- positioning of phantom sources in the stereo panorama will depend on direct, but that isn't critical
directivity does not need better than spinorama, predicted response can be omitted
- rooms spread wildly in their properties, predictions are nonsensical
- better encourage people to measure what a certain setup actually delivers, promote a service that would possibly take care of this
- encourage appropriate equalizing
- still keep high standards for smooth directivity, but relax a bit, perfection kills
come to consider non linear distortion
- IM needs a reasonable concept, multitone is very often misunderstood and misused, IM destroys music
- HD is not that critical due to anyway very prominent overtones in any relevant program material
- but please equalize before measuring, especially in the bass
Ordered a new mic so I can get back to data. I was hoping the upgraded MiniDSP mic would go above 20K, but seems not. One that does is $600.
The Panasonic WM something of Linkwitz fame can still be found for purchase. Last summer I recorded bats in my backyard using it. After frequency transformation from about 45kHz (!!) to 2kHz with audacity I could listen to it. I couldn't determine the species, though. But, that wasn't a prob of the mike. They were not after food, it seems, just navigating, I was told.
