Spec
I/O
Microphone Inputs (XLR – balanced)
Two
High Impedance (Hi-Z) Instrument Inputs
Two
Analog Line Inputs
Four
Analog Monitor Outputs (DC coupled)
Three (two stereo headphones and one stereo master)
Digital Output Port
One (USB OTG)
Audio to Digital Conversion
Dynamic Range
122 dB, A-weighted
Signal-to-Noise Ratio
-122 dB, A-weighted
Total Harmonic Distortion + Noise
-116 dB, -1 dBFS
Digital to Audio Conversion
Dynamic Range
127 dB, A-weighted
-127 dB, A-weighted
-120 dB, -1 dBFS
Mic Inputs (XLR balanced)
Frequency Response
20 Hz to 20 kHz (+/-0.3 dB)
Minimum voltage gain
0 dB (fader @ unity, -8 dB pad)
Maximum voltage gain
62 dB (fader @ unity, no pad)
Nominal input level
-16 dBu through -66 dBu (fader @ unity, no pad, @ +4 dBu output)
Maximum input level
+16 dBu (fader @ unity, -20 dB pad)
Expected source impedance
150 to 2000 Ohms
Actual load impedance
1200 Ohms
Instrument Inputs 1/2
Frequency Response
Input Impedance
390 kOhms, typical
Maximum input level
+16.5 dBu (fader @ unity, -20 dB pad)
Line Inputs 1/4
Frequency Response
Maximum level
+24 dBu
Nominal input level
+4 dBu
20000 Ohms or less
10 kOhms
Line Outputs 1/2 (6.35 mm TRS, Unbalanced)
Frequency Response
Maximum level
+24 dBu
Nominal input level
+4 dBu
Minimum load impedance
600 Ohms
Headphone Outputs (Stereo, Unbalanced)
Frequency Response
20 Hz to 20 kHz (+/-2.5 dB)
Load Impedance
16 to 600 Ohms
Maximum Output Level
+18 dBu, no load
+18 dBu, 600 Ohms (7.94 Vrms)
+16 dBu, 100 Ohms (6.3 Vrms)
+14.6 dBu, 32 Ohms (5.4 Vrms)
+8.6 dBu, 16 Ohms (2.7 Vrms)
