icepower as1200 and electrical impedance.
Ema79
Good morning everyone. I was looking for a pair of woofers to include in my speaker project, and I finally found a pair that suited my needs. But they have a 16-ohm impedance. So I looked at the specifications of my low-frequency amplifier, an IcePower 1200 AS2, but I couldn't find anything about 16-ohm impedances.
The question is: is this amplifier suitable for 16-ohm loads? If so, does it perform better or worse than a 4-ohm or 8-ohm load? Thanks so much for your help.
It will work fine, it will put less power into them but that's not an issue as that amp has a lot of power.
Only thing I'd be cautious of is that if they are vintage drivers they may have very low power handling.
Assuming the voltage remans the same the power will be cut in half when the impedance doubles (inversely proportional). I can see from the specs that the power is half at 8-Ohms compared to 4 which means the voltage is holding constant and you can expect 300W.
16-Ohms isn't common and they are likely "intended" to be used in parallel. Two in parallel is 8-Ohms and you'd get 300W per-speaker. And you can get the same performance with one amplifier driving both. Four 16-Ohm speakers in parallel would be 4-Ohms and still 300W per speaker.
...Some amplifiers can't put-out the "expected" increased current, the power won't increase inversely proportional to the impedance and it will clip at a lower voltage. Many amplifiers can't put-out double the power at 4-Ohms so I'd say the ICE power is a good design! (If the impedance is too low for a particular amplifier it might burn up or go into thermal shut-down.)
Hi, thanks for the detailed reply. In my project, I don't need to run multiple drivers in parallel; I simply need a good driver to use in a closed box. In the pro world, it's difficult to find a good driver with a Q factor of around 0.40 suitable for this purpose. So my search is limited to two or three drivers, including two 16-ohm ones.
