This web page will take generic EQ recipe in text format and give you a file that a convolver can process, which results in identical transfer function as the EQ.
It seems to work fine from my testing.
The advantage is that some processors can only do 8 filters. Native Android tools are approximations of proper EQ. A convolver is precise and can equal an arbitrary number of PEQ bands.
The options are:
Just open the index.html file in Chromium based or Firefox browser.
The options are:
- Analog-matched (default): the magnitude of each IR follows the analog filter prototypes exactly all the way to Nyquist, so bells and shelves keep their shape at 44.1 and 48 kHz. Phase is minimum phase, built with the cepstral method.
- Bilinear RBJ: classic Audio EQ Cookbook biquads per sample rate. Filters near Nyquist are squeezed toward 0 dB at Nyquist (cramping). Filters at or above Nyquist are skipped.
- Δ is the largest difference between the file and the analog curve from 20 Hz to 20 kHz. Very short IRs also show a Δ at low frequencies because they truncate the response.
- Tail is the peak level in the last 5% of the file. Below −90 dBFS is clean.
- Export to any or all common sampling frequencies,
- multiple .wav file formats from 16bit PCM to 64 bit float supported
- multiple Impulse Response sample lengths up to 131072
- mono or stereo (identical L and R)
- Normalization to -0.1dBFS, Gain from the PEQ text file, or no gain adjustment.
- Fade out of the last 5% of samples to avoid abrupt truncation
- Dither for 16 bit .wav files.
