I thought this was cool
RayDunzl
Central Scrutinizer
Riverview FL
Wow...
Soniclife
It's like a magic trick.
Shame is not an HD video.
restorer-john
The gas cooktop is really cool, but I can't see that working when its hot- may have to wait for it to cool before retracting it.
Blumlein 88
I was wondering how they made those parts. It is wire Electrical Discharge Machining. EDM, not to be confused with Electronic Dance Music. :)
A brass wire carries very high voltage. The material to be machined is placed in a tank of liquid dielectric fluid which can be de-ionized water. The electrical pulses at high frequency cut the material and the brass wire actually never touches the part being machined.
https://en.wikipedia.org/wiki/Electrical_discharge_machining#Wire_EDM
restorer-john
Wow, that is just amazing.
One of those pieces reminded me of the Fifth Element Temple key...
Soniclife
Can that do the rounded ball shapes they were showing? I cannot see how a wire could do that.
I just searched for Electrical Discharge Machining in tidal, sadly no hits.
Blumlein 88
I wondered the same thing myself. Even the helical shaped pieces seem hard to do with a straight wire. However, rotating the machined piece and doing multiple slices in small steps could certainly create most any shape desired I'd think.
I helped make some speakers once out of multiple layers of flat MDF. They were stacked vertically, 3/4 inch thick. I used a jig saw to cut rounded complex shapes and angled each layer on the cut. I and a friend were able to create compound curves for a complex rounded low diffraction shape. But we only made a series of straight angled cuts. We did have to sand the end result, but that was mainly for glue that oozed out of the clamped together pieces. The wood itself fit together just so, and really needed nothing.
