312elements
Is it your perspective that having the woofer adds to the diffraction by disrupting the baffle face below the concentric driver? I envision this could be the case. Perhaps that is why on the Blades and LS60 KEF moved the woofers to the sides, but I don't know.
My perspective is that all speakers are a compromise.
The R3, like most speakers keeps the drivers close enough together so that the sound seems to be emanating from one place. It's a very well designed speaker. The LS50 does that trick better by not having a second woofer at all. Rather than being close enough not be problematic, it's an absolute best case scenario. In the same way that 3 ways have some advantages over 2 ways, a point source driver (or coaxial) has advantages over a dual alignment. The extra woofer isn't causing diffraction issues. The signal visually looks different emanating from the speaker.
The diffraction in regard to enclosure design takes that one step further. Again, you've got a best case scenario here for imaging.
With regard to the LS60 and the Blade, my hypothesis is that it has more to do with WAF and internal resonances. You could use various materials to dampen a resonance as is often done, the dual opposed woofers on those designs cancel the resonances and stop them before they become a problem that has to be solved. It's pretty cool tech, especially the way KEF does it with the shared magnet design. It's actually one unit with two drivers that spans across the enclosure.
The R3 does lots of things better than the LS50. There's more excursion in the coaxial driver in the LS50 and that excursion negatively impacts other aspects of its performance. If this, along with the deeper bass appeals to you, then it's a better candidate.
As a big fan of full range speakers I've built many variations borrowing ideas from KEF along the way and testing theories. Full range speakers have their own strong points and weaknesses and for many the compromises aren't worth it, but it's hard to find a speaker that images better than a well made full range driver in a well designed enclosure. The bass will likely be lackluster, if the driver is too large, you will have beaming issues. They typically perform best without toe-in (because the frequency response is most even 15 degrees off axis) which can cause problems with reflected response but they image like nobodies business. All compromises.
