I pulled the trigger on Ascend Acoustics ELX tower
I uploaded new Anthem ARC genesis with new speakers and Velodyne HGS 12 sub, an older sub but a great sub for size and space. Next, I need to improve room with some room treatments not doubt, and some manual tweaks of the ARC Genesis. Thoughts/advice there? I'm not well versed in that area and don't want to make changes that can make it worse. The 6db room gain seems obvious place to lower perhaps. Room is not as reflective as pic suggests: just outside of photos is large rug, couch with pillows, several large puffy dog beds, etc. Next is to address the wall to the right, and perhaps add some wall treatments. That's the area in need off addressing, with SO approval factor to be considered.
That's a nasty null around 180 Hz. Fix - under Set Speaker Levels drop the SYSTEM-WIDE LEVEL TARGET at least -1.5 dB for starts. May take -2 dB or a -2.5 dB adjustment. Bottom left of that screen Hit Continue and have a look at the adjusted ARC graphs. Should take care of it smoothing it out. Review and if satisfactory upload to your Anthem, SAVE file and run Auto Phase Adjustment. I turn off/on my unit which insures the unit is programmed.
I installed 2" X 2' x 4' acoustic panels around the room, about 10 of them. I also added artificial trees and one bush, 12 layer deep laser cut art for diffusion, the big and deep wool room rug. It all adds up. This guy's art is incredible. I've got the Deer and 2 other pieces. https://www.etsy.com/shop/STEREOWOOD?ref=yr_purchases
I'm going to work on that now. I think the system is as good as it's gonna get for a while, the room is the obvious place for any improvements. I'm thinking at least the rear wall, the side wall to the right, and the back wall are the areas to address as obvious locations. Using what panels, etc, I'm not sure.
Did you work on that null via ARC?
The unit will not open the last file I saved, so I need to re run the ARC, save a file, then tweak that setting. That part is a PITA I find, but worth it.
Instead of a drawing, I figured a short vid was easiest to show my less than optimal room where system currently exists. Last ARC Genesis run is in #43 above. I am looking for suggestions for where to improve that space knowing room correction only gets me so far. I assume obvious places to address would be the back wall (behind system) the side wall (I can move that shelf up too) and the back wall behind the couch. I know, couch against wall is a no no, can't be helped.
Looking at offerings from:
DYI is possible too, but have to also consider SO approval factors.
Thoughts/advice on next steps?
I did. Not sure what impact it had, subjectively seems a bit smoother to me. It would seem such a null has to be addressed via room treatments no? Here's new ARC run. I wish there was more 2ch Arc info out there as to adjustments beyond/after running the auto fix. Only one I know of is a short vid from Gene D. I didn't mess with base boost and such as he's not using a sub, but I did lower max correction to 1k from 5k.
Here's my thoughts on the ELX Towers as non pro reviewer of audio gear. It's a purely subjective discussion, but I refer to their use of Klippel NFS measurements as one reason I chose and recommend them:
They are approx 2' from the rear wall and that one side wall. Speakers, depending on their dispersion patterns, toe in (or lack there of), and excellent room correction via ARC Genesis, impact the sound for sure. I do need to add some room treatment to the rear and side wall, but it has to look decent and not be silly $.
Not sure what will happen with the FM8 subs as they only way they fit in that space is to be speaker stands.
i will send you my address lol
They sold quickly. I didn't want to put them in storage. Sad they stopped producing them.
...and just when I thought I really didn't need them :)
I'm afraid you do! I would like to hear them with the dome tweeter too for comparison, I see why the RAAL so universally loved.
I didn't even know that's what I was liking when I first heard the BMR Monitors...now I'm hooked:)
It is no surprise two companies known for their focus on high quality drivers and balanced accurate sound chose that tweeter. That's what they call a sign. :cool:
Unfortunately Philharmonic Audio is moving away from the RAAL, which is a little wider than the AMT they use to replace it. I'm pretty sure I can hear the difference and it isn't massive but it's there.
I saw that yes. I got the impression they offered both, but maybe that depends on models, not clear to me. I saw they claim they are indistinguishable under blind testing.
They probably are indistinguishable in a blind test. Much of what is talked about here on ASR is not in fact audible to us. If you like the sound of something BUY IT, who cares about what others think...... Also there isn't much that is universally better. Some people may like the RAAL tweeter over the AMT, others may think the reverse. Many people way over analyze issues here. Probably has something to do with Audio SCIENCE review. LOL.:D
