Mark609
- Joined
- May 2, 2025
- Messages
- 171
- Likes
- 182
Beats the Philly 6 month drill! Tina, Dave's wife is a sweetheart. Easy to work with/thru. They triple box them too!Sadly, I was told 3 weeks ish.
That's why I gave up on getting a BMR super as I wanted originally. I wanted another 3 way stand mount to replace the MO and stay with the subs, but I went a different direction.Beats the Philly 6 month drill! Tina, Dave's wife is a sweetheart. Easy to work with/thru. They triple box them too!
ELX towers are a perfect size for the space
Looks great! Can you share the name of the vendor? Thanks!large custom made room wool rug from Etsy/India
And the most important thing in a HT, comfy chairs for everyone!Well, my HT may look a little cluttered but I tamed a nasty clap slap loud room big time with 8 layered wall art for diffusion, artificial trees, 2" acoustic panels, large custom made room wool rug from Etsy/India, window treatments.
"A river runs through it"Looks great! Can you share the name of the vendor? Thanks!
Dina, not Tina.Beats the Philly 6 month drill! Tina, Dave's wife is a sweetheart. Easy to work with/thru. They triple box them too!
Which Monitor Audio speakers are those?
What's "SO", and "MO" ?
It's really unfortunate that philharmonic audio can't fulfill orders more quickly.That's why I gave up on getting a BMR super as I wanted originally. I wanted another 3 way stand mount to replace the MO and stay with the subs, but I went a different direction.
Yes, that's the model.Gold 100 6G (I'm pretty sure!)
That's next step for sure. What would you recommend?Welcome to AA!Leap of faith for me after a ton of research. Think you're gonna be really impressed.
I too had the same quandry - is my end game gonna be Phil HT Towers with subs or ELX? Chose ELX-RAAL with subs. They are amazing. Dave is almost OCD in getting it right with all his toys (Klippel and such) and revisions. Can also recommend his Horizon V2 center if you have the room. Incredible center.
Don't get me wrong, the ELX has robust clean bass output and for most music you won't need a sub. Watching the 6" woofers pump back and forth is a hoot open wide. BUT, in my mind, for "more linearity" I plugged the ports with closed cell foam and cross them over to 3 subs at 70 Hz for reference theater. Bass is immersive, just disappears.
ELX playing Dire Straits and a whack of a snare rim shot is eye opening, vocals smooth as silk, perfect dispersion vertical vs horizontal, pure sweet sound as it was intended is expressed.
Just installed a 3 channel Hypex NCx500 for the Ascend A. LCR's and man do these puppies sing!
Plugged port DATS run.
FIY. Unplugged
You may want to install some room treatments for those side walls.
Have fun!
