I pulled the trigger on Ascend Acoustics ELX tower
WillBrink
I purchased with RAAL Tweeter in natural bamboo. Two brands I have wanted to try forever, mostly due to this forum, was Ascend and Philharmonic Audio. I hesitated to go the floor standing route, but I wanted three way with dedicated midrange and those ELX towers are a perfect size for the space, especially if they don't need subs to sound good. Currently, I'm using below set up. The space is less than optimal but that's my SO approved space for entertainment currently.
Why change? The SO hates those MO speakers. Every time I, or she, puts on music, I have had to hear how much she dislikes how they sound and how they look. She was a big fan of my ATC SCM 19s actually, and I'm hoping the Ascend's are a little more laid back and neutral vs the Monitor Audio, which are very revealing and downright ruthless with anything but high quality recordings. The ATC's were a bit more forgiving in that regard.
If we both like the ELX towers (and my research suggest we will) as much I hope I/we do, then I will sell the MO and decided what to do with the excellent subs. May have to put them in storage until I have more space, not sure on that one. I will report back to this thread once they show up and are set up and how they sound with that gear in the space. I hope they are forgiving of such a location. The Anthem ARC helps. I need to work on room treatments too. There's a large rug just out of the picture and couch and lots of pillows and such on other side, so not as reflective as that pic looks, but it's far from acoustically perfect to be sure.
I think wide directivity helps bad recordings. I think it helps good recordings too.
If your front and rear wall are short you’re going to face a lot resonance and flutter echo. No speakers are going to fix it. Looks like you have a pair of rythmik 8 inch sub. Dont sell or throw them away. They don’t sell these anymore. Just implement better
Please forgive a stupid question...but how did you decide? I have the same quandary, but short of a west-coast road trip to audition the ELX, I guess it's a leap of faith. I'm sold on the wide dispersion of the RAAL (even tho Ken assures the AMT is voiced the same), and the added bass response of the ELX may be worth the leap over the Monitor? I'm thinking I'll just build the Monitor and hit Acoustic and Burning Amp on a west-coast venture next year:)
Philharmonic has a six month wait if that matters. If using a sub there no difference really. Also RAAL and AMT are not the same even if they are 'voiced' similarly
Welcome to AA! :D Leap of faith for me after a ton of research. Think you're gonna be really impressed.
I too had the same quandry - is my end game gonna be Phil HT Towers with subs or ELX? Chose ELX-RAAL with subs. They are amazing. Dave is almost OCD in getting it right with all his toys (Klippel and such) and revisions. Can also recommend his Horizon V2 center if you have the room. Incredible center.
Don't get me wrong, the ELX has robust clean bass output and for most music you won't need a sub. Watching the 6" woofers pump back and forth is a hoot open wide. BUT, in my mind, for "more linearity" I plugged the ports with closed cell foam and cross them over to 3 subs at 70 Hz for reference theater. Bass is immersive, just disappears.
ELX playing Dire Straits and a whack of a snare rim shot is eye opening, vocals smooth as silk, perfect dispersion vertical vs horizontal, pure sweet sound as it was intended is expressed.
Just installed a 3 channel Hypex NCx500 for the Ascend A. LCR's and man do these puppies sing!
Plugged port DATS run.
FIY. Unplugged
You may want to install some room treatments for those side walls.
Have fun!
Measurements, feedback, looks, dimensions, materials used, and waiting time. If I hate them, they will be sent back. That's a PITA for sure, but I have done it before.
FIY. Unplugged
Have fun!
Room treatment is much needed but a key SO sticking point to deal with. As you can see, don't have the room to run floor standers and those subs and positioning choices are limited. Only way I got to enjoy subs was by making them the speakers stands and using subs perfect dimensions to make it work.
Well, my HT may look a little cluttered but I tamed a nasty clap slap loud room big time with 8 layered wall art for diffusion, artificial trees, 2" acoustic panels, large custom made room wool rug from Etsy/India, window treatments.
I wish I had the space for a proper HT. I did in my last house, downsized some when I moved to FL. Not having a proper HT is getting on my nerves over time.
Listen first. The stability and control of the reflections from the RAAL and other drivers can mask some room issues above Schroeder
They are approx 2' from the rear wall and that one side wall. Speakers, depending on their dispersion patterns, toe in (or lack there of), and excellent room correction via ARC Genesis, impact the sound for sure. I do need to add some room treatment to the rear and side wall, but it has to look decent and not be silly $.
Not sure what will happen with the FM8 subs as they only way they fit in that space is to be speaker stands.
Looking forward to your impressions of the sound and finish on the ELX towers. "IF" I ever upgrade I will have to decide between the AA ELX RAAL tower and the MoFi SP888.
Sadly, I was told 3 weeks ish.
I have not seen any objective measurements on those MO's but subjectively, they don't sound narrow to me. I'm not very sensitive to that issue regardless. If I like the sound of a speaker, I usually like it regardless of where I'm standing or sitting more or less.
