I need help, should I return my X4700H?
Scubaduderon
I've had my x4700h for a few months, and I've recently noticed that I get soft, extremely distorted sound from my surround speakers while watching CNN, MSNBC and the like. Is this normal, or should I return my unit for a new one? It only seems to happen with audio coming from certain cable channels, ones which may not have any surround signal. I just put on a superman movie on cable and it was fine. Netflix, hulu, Amazon prime, all being streamed, are fine.
MASKINEN
Sweden
Well it sounds like you hear this when you play a stereo signal in surround mode. The receiver creates a surround sound from the stereo input signal. If that’s the case, then I would say it’s normal.
But I’d it’s not a stereo signal then yes something could be wrong.
raistlin65
Grand Rapids, MI
S
Scubaduderon
Thanks guys. How can you tell if its a stereo signal vs surround? I've got it set to auto, which I believe detects the signal and adapts accordingly.
escape2
USA
Hi the "INFO" button on your AVR's remote. It should show you details about the incoming signal, including how many individual channels it contains.
Or just use the "AVR Remote" app on your phone or tablet to display this info.
Third option is by logging into the AVR via your web browser - just need to know its IP address.
