In this Head-fi post (https://www.head-fi.org/showcase/k240-df.12176/), user asymcon reviews these headphones and recommends rewiring them to improve the sound. Since I'm somewhat handy and I've found that the original cable only goes to one channel (left, and from there it goes through the metal headband to the right channel), I've thought about changing the cable since the cost wouldn't be too high. I'm looking for an unbalanced option like the one with the original AKG headphones.That's why I need your help with some aspects I'm not clear on. There are two options for rewiring them:
1. Like user asymcon suggests, using a Starquad microphone cable for rewiring. These cables have four connections (generally two white wires, two blue wires, and a neutral/ground wire). How would the connection be made? Would I use the two white wires joined together for one channel, the two blue wires joined together for the other, and would the ground be common to both channels?
2. The other option would be a dual cable that is independent for each channel (like most over-ear headphones that have one cable for each earcup). In that case, each cable would carry a signal (left-right) plus a ground wire that wraps around the signal cable. Wouldn't this option be more immune to interference since the signal cable would be protected by a ground wire, and wouldn't it also prevent the signal from reaching the metal connectors on the headband, which would degrade the signal a bit? I've attached photos so you can see the AKG connections.
On the other hand, what cable would you recommend in each case? I'm looking for something not too expensive, around 2-4 Euros per meter. What characteristics should I look for (OFC, for example)? Do you recommend replacing the 6.35mm stereo jack with a better one (for example, a Neutrik) or reusing the one that came with the headphones? Any other suggestions?
And thanks in advance for your help.
