Can you help me with understanding the sound coming out of a Yamaha HPH-MT8 headphone?
It sounds "thin" compared to two other headphones.
One of the tracks I used:
If I understand the spectrogram correctly, it tells me there is a lot of base with high amplitude from 30 Hz to 500 Hz in this song.
System used:
I am actually listening to the HPs via a notebook's 3.5 jack output. The notebook's audio chip is a simple Realtek one:
I borrowed most of the stuff to compare the notebook's internal audio with an external old RME Babyface interface. If I can hear, that the sound quality from the Babyface is better than the one from the notebook, It might be, that this is also true for a mobile phone (cheap model with a jack output) compared to an external dac/amp via usb. If I hear a difference between the notebook and the Babyface I might check if I can afford such a mobile dac.
But because of the weird sound of the Yamaha I am unsure whether there is something wrong with the Yamaha or whether there is a variable influencing the sound I have not yet considered.
- Yamaha HPH-MT8 - low base intensity, mids and highs are emphasized - I must increase the volume to get a feeling of base, but that volume is already to loud for normal listening for me. On the other hand, if there is base then it sounds controlled.
- Sony MDR-7506 - base is there and sounds ok to me but a bit muddy, mids and highs are less pronounced than with the Yamaha (but still a quite high sounding headphone)
- B&W P7 - base is emphasized and muddy, mids and highs are ok for me (this headphone gives the most "easy listening" of the three, but the base gets somewhat out of control)
System used:
- Source is 44.1 kHz 16 bit flac
- Player is MusicBee set to:
- WASAPI (Exclusive)
- volume to 100%
- dsp and EQ is off
- replay gain is off - Audio device (Realtek chip) is set to 44.1 kHz
- All audio enhancement features are off
- OS is Windows 11
