guitar sam here and i'm quite aware that flac 16/44 at 0 compression is the same as flac compression level 4 however in a/b testing i can pick out the flac 4 every time because it's like comparing mono to stereo just like listening to a remastered vinyl album cut from a digital copy of the master will have mono depth perception which is nothing more than a vinyl cd and vinyl cut directly from the reel to reel master will have stereo depth perception which is why vinyl made a big comeback because teenagers started listening to there parents old vinyl record and when the record companies started pressing vinyl again they made sure that the new vinyl had mono depth perception to remove the hypersonic effect which made your brain release dopomine and you no longer needed prozac. it's only a conspiracy until you can prove it. my settings for izotope rx5/rx7 are comercial flac at 16/44 compression level 0 to level 4 + i use the time & pitch filter to remove the dynamic compression from digital audio which increases the dynamic range along with the sound quality.
Very cute how you introduce yourself as "guitar sam" at the beginning of each post.
However, we have already "proved it". The two tracks that you believe you're hearing a difference between are absolutely
identical down to at least -385dB (limit of calculation), which is almost 300dB below the absolute threshold of audibility for humans.
It literally does not matter what your software is or what your settings are; the files are identical. Case closed.
Goodbye
