Blumlein 88
- Joined
- Feb 23, 2016
- Messages
- 23,571
- Likes
- 44,637
I already said you place the phone and don't move it. I'm not talking hand held here. Otherwise youare preaching to the choir. Those not in the choir just plain aren't hearing us when we tell them use a meter. It is ten times better, ten times or more consistent and about 10 times easier. Or I guess not. What they are doing is easier, and of course wholly inadequate. So if we could get them to do something the way it seems people automatically want to do it only in a way that works it would be a step forward.Your phone must be super stable for this to work. A deviation of 2.5 cm from the source would already be the .1 dB difference in gain that is needed for level matching. And even then you'll need some long averaging, and you then have no way of knowing if the differences are from some room source, or a gain difference. it would need several runs at random times to get this done. Just use the f*ching DMM and save you all the trouble
This brings us to another point: Equally for the blind test to work, you yourself cannot move more than 2.5cm as well while performing the test, otherwise the gains won't match either. Never mind different reflections and other room effects that can be highly localized. All of these things just show how silly it is to use speakers to try to perceive differences that are so tiny.
That's the whole point, isn't it![]()
Just tell me how often does somebody use a phone or SLM for matching and we tell them use a meter and they say, "okay, i didn't know I'll use a volt meter"? It happens, but at least 5 times as often there is a series of posts about it and even after all of that I don't think even half pay attention and do it right.
