Tks
- Joined
- Apr 1, 2019
- Messages
- 3,221
- Likes
- 5,496
Anytime there is traffic while on my computer i.e. opening a new website, or downloading/uploading something, I can hear some sort of static sound from my IEMs. RME DAC hooked up to the PC but only with Toslink. If I pull the Toslink connection out, I can't hear it.
Don't understand how that's possible seeing as how there is no sound playing while this happens (it can be no sound, or during sound, makes zero difference), so it's not like the PC is sending polluted data or something (even if it was, the WiFi on this desktop is using an external WiFi solution through PCI-E interface with the antena being outside of the case, so it's not like it's creating any IEM internally to begin with that would make some sense).
I got a bunch of IEM's that do this, but I just tried the KZ ZSN I had next to me just now, and it still occurs. Oh and interestingly enough, it only occurs on the right channel.
Really wish IEM makers would stop with these overly sensitive IEMs. Every device on this planet can power IEM's these days (I'm usually around -40db to -30db max on the IEM port from the RME, and these things are loud.. Hell I can run HD6XX's from the IEM port and it's still enough for 99% of music I listen to).
I recall many cellphones back in the day had built in radio, but only usable if you plug in headphones or IEM's so the wire serves as an antenna. Antena for 2.4Ghz WiFi now though? Sheesh >_>
Anyone else experience anything like this?
