shal
Hi
I am considering use Hypex UcD700HgxHr.
But it's hard to find measurement , the only one I found is in the Hypex document but it's only THD (and no THD+N) and only at 1khz.
Do you know measurement of ampli that used this module ?
Ok it is now quite old, but the difference with and purifi is audible ? Thd < 0.02% is pretty good and perhaps enough
My purpose is to set two modules in a old Crest FA901. The power provides a +-82V that match udC700 needs (85V (in 75-96V range))
Do you think that I can achieve a very good amplifier with this way ?
Thx
Thx
