I think that's a bit harsh. I have avoided stepping into this; I respect both Alan and John, and they are arguing from valid but opposing sides. The issue is not the filtering, except that Hypex's output cap appears underrated for the FTC test (they appear to leave thermal management to the end manufacturer, not atypical as they cannot control that aspect of the final design). I do not recall seeing a five-minute 20 kHz full-power test and Hypex's datasheet says pretty clearly the capacitor is not rated for that. Note many amps have included output coupling caps that may have the same problem (I expect myself, Alan, and John have dealt with a few over the decades); in a class D design, the capacitor is actually more of a decoupling capacitor since it is not in series with the output. The FTC also required 1/3 power pre-conditioning (I think it's 1/8 now but don't quote me) for an hour; that is actually pretty stringent for a class AB amplifier but not a big deal for a typical class D amp.
From my point of view there are a couple of (OK, three) things going on. The following is my opinion and I apologize in advance for misrepresenting Alan, John, Hypex, or any other parties past, present, and future (hopefully that's CYA enough).
- Hypex states you cannot (should not) exceed 30 seconds for a full-power test over 5 kHz due to the output capacitor's ESR. That parasitic resistance heats up and can cause capacitor failure.
- Thermal management is left to the final manufacturer and is another bound on long-term power dissipation. Fair enough, Hypex provides modules, so it is up to the assembler to design the heat sinks and chassis to support the thermal load.
- Then the big debate about the FTC specs for the US market. The FTC says it should provide full rated power over the rated full-power bandwidth for five minutes (though there are some caveats on that now). The final amp (any amp, not specifically talking about March Audio) may or may not meet that spec based on the thermal design; but it seems like the module itself is limited to <30 s over 5 kHz.
Does it matter? There's following the FTC to the letter of the law, and real-world usage. John is arguing for the former and Alan for the latter, both from a sense of "right" and adherence to best principles for the consumer. I can read the data sheet (though frankly have not except a few snippets being debated here) and understand the specs so from that point of view Hypex is not doing anything wrong. It is up to the manufactures to decide how to rate the final product. That's where Alan and John get crosswise; until John sees a full-power FTC power test, in his eyes it is not FTC compliant (mine too). Alan feels the FTC test is not reasonable and provide lots of evidence to back that up (ditto). Knowing the dynamic nature of music, I can accept that many (probably most) Hypex (etc.) amps do not met the FTC spec, but as long as the actual specs are provided and the amps are not claimed to meet the FTC tests, I can make an informed decision.
There is risk either way; risk there is less margin in the class D design for thermal and sustained HF output; and, risk in cost, weight and power by purchasing an amp that meets the FTC spec but may be overdesigned for the real-world task. Up to me to choose. Alan and John have both made good cases for their point of view IMO.
Hopefully my last word as I really have nothing to add to this discussion. - Don
