Watch the videos and you will find it stop with this nonsense.
I can understand why you are feeling frustrated with some of the responses you've gotten. At the same time, I don't think you have been entirely clear in what you're looking to achieve with a new amp - the information about that has sort of emerged gradually, bit by bit, over the course of your comments, and it is understandable why folks experience that as frustrating in its own right, "moving the goalposts" so to speak. First you posted that you're looking for an amp with "good/wide soundstage." Then several posts later you revealed that you don't really level-match amps when you're listening to them comparatively; and then several posts later you clarified that you're looking for an amp with a switching power supply because you have a DC-induced mechanical transformer hum problem, and in most cases a switching PSU means a Class D amp (which you are correct about).
Now that we have the full picture, I think we can summarize the discussion in a way that helps make it clearer to everyone, including you - and might also be helpful to you in making a purchase decision.
1. Soundstage: No one here can give you any guidance on buying one particular amp over another because one has an inherently bigger soundstage. The reason no one can give you that guidance is that on the whole amps do not produce bigger or smaller soundstages -
but we don't have to fight about whether that's the case - the point is that you're not going to get amp recommendations here based on soundstage performance. Do with that fact what you will.
There are 4 reasons I can think of why an amp might conceivably produce audibly reduced or increased perceived soundstage size - although none of them comes into play with the class of Class D amps being discussed in this thread. (A) an amp with unusually bad, truly dreadful crosstalk performance might produce worse perceived soundstage imaging. (B) if an amp were clearly underpowered for your application (speaker efficiency, room size, and/or desired listening volume), that lack of power would likely make itself most apparent in the bass frequencies, and the nature of bass frequencies (being widely- or omni-directional) means that they can disproportionately contribute to a feeling of envelopment or big soundstage - and so weak bass could conceivably negatively impact the perception of a big soundstage. Or conversely, excess bass distortion from an amp with insufficient power could produce the perception of a larger, "fuller" bass soundstage from the added distortion. (C) some less-expensive Class D amps - so-called "chip amps" - that don't use post-filter feedback are load-dependent, meaning the top 1-2 octaves of the audible range can be slightly attenuated or accentuated depending on the speaker you use with them - and that could potentially impact the perception of treble "air" which therefore could impact the sense of ambience and spaciousness. And (D) as mentioned above, significant 2nd harmonic distortion at some frequencies is known to produce a sense of increased ambience and air and therefore potentially increased soundstage size.
But again, the Hypex and Purifi-based amps being discussed in this thread don't have those issues - their distortion is far too low, their crosstalk performance and power capabilities far too high, and their ability to remain linear with different speaker resistance loads far too robust, to produce any of those issues. Unless you get the very lowest-powered Hypex amp available AND use it with really inefficient speakers AND are in a large room listening from a long distance away, you're not going to have any issues with any of these amps.
2. Bruno Putzeys' opinions on Class D amp sound: The comment you were thinking of was from 12 years ago. That's a lifetime in the recent development cycle of these amps. The main issue he was concerned about back then was something called hysteresis distortion, which was a thing in the first(?) generation of Hypex amps. Whether or not it's actually audible, Putzeys' claim was that it does not produce subtle issues like a reduction in soundstage or reduced "slam and pacing" or any other traditional audiophile term for subtle perceptual variations. Instead, his claim was that it produces a random but more or less constant, subtle click/pop/graininess from a very particular mechanism of distortion related to magnetization of a speaker driver's ferrite core. Purifi designs - and the Hypex designs that are current today - are designed to deal with this. So it's not an issue, has not been an issue for a long time, and was never an issue that would manifest with regard to perceived soundstage size.
3. DC-induced amp transformer hum: A switching power supply will indeed solve your issue. And a $150 DC blocker with your current amp will very likely solve the issue too. As will the more expensive isolation transformer solution recommended by others.
4. Perception of different sound from an amp: If you're perceiving night-and-day differences in soundstage size between different amps, then that's what you perceive and your experience was real in the sense that you did indeed really experience it. But as I noted above in item 1, no one here can recommend any particular amp on that basis, for the simple that they don't hear those differences and there is no known intrinsic characteristic of these kinds of amps that could reasonably be hypothesized to cause such differences. So you'll have to trust the opinions of others elsewhere online who claim to hear such differences; or you'll have to make a purchase based on guesswork; or you'll have to seriously consider that what you've heard might not be intrinsic to the amps. My own view is that the fact that you haven't compared them in a properly level-matched way is the most likely explanation - but you're under zero obligation to give my opinion any weight, so you'll think whatever you want to think.
If it were me, I'd just get an Audio By Van Alstine DC blocker (or a similar model) and see if that solved the hum issue. Super easy to install and try, inexpensive so no huge loss if it doesn't work, and wouldn't require me to change the actual sound-reproduction gear that I was already happy with.
