. Black Friday -25% Hypex
Deux amplis Mono Nilai 500 : 1230€
Un Ampli stéréo Nilai 500 : 918€
Thanks terryforsythe there was no indication on the Hypex website that this kit was available from a third party.There is an upgrade kit available:
Hypex Nilai Stereo to dual mono adapter kit
This Hypex Nilai Stereo to dual mono adapter kit allows you to upgrade your Hypex Nilai Stereo kit to full dual mono operation. If you don't already have a second PS500DIY power supply, you will need to purchase one separately.kjfaudio.com
Also, the following thread has the information necessary to do the upgrade yourself:
Hypex Nilai stereo/mono kits cases
Hi dear members of ASR ! This is my first post here, to ask some informations to Hypex Nilai stereo/mono kits owners. Sorry for my poor english level, I'm french :-) I plan to buy a Hypex Nilai stereo kit and do some modifications on it (adding a second Nilai PSU to do a dual mono amp). But...www.audiosciencereview.com
I upgraded mine. Here are some notes I generated at the time: https://www.audiosciencereview.com/...lai-stereo-mono-kits-cases.48769/post-2055317
FYI, my amp runs a little warmer with two power supplies. It definitely will not be an issue in an open cabinet, but may or may not be an issue in a closed cabinet, depending on how air tight is the cabinet and the size. That being said, it still runs quite a bit cooler than my old Adcom amplifier.Thanks terryforsythe there was no indication on the Hypex website that this kit was available from a third party.
Whichever lowest settings gives you the desired maximum output you need. Sound wise there will be no difference.Which settings do you use? Low, medium or high?
Indeed the 1000ASP is quite outdated compared to current SOTA class D.The sound is really excellent and a significant improvement from my previous pair of Bel Canto REF1000 monos, which is probably not surprising given these use an ICEpower 1000ASP module which dates back to 2004. Basically it’s easy to hear how far Class D technology has progressed in the last two decades.
Medium: Paradigm Studio 100v.3, peaks to 90 db with volume -20 and balanced output of Okto 8 Stereo DACI try the nilai500 in mid gain and I like it, so I tried it on low gain to try the best settings.
I think it is a little better, but for sure it is very low volume. I need to turn up the knob about 15db and it still is lower than before.
I have a Kef reference 205 with a sensitivity of 90db.
The differences on measured performance between low, medium and high gain are small and well below the threshold of audibility.
Yes, he does, to put the subjectivists at ease. But it's pretty theoretical, and in practice, trying to hear noise at -108dB is like listening for the sound of a pin dropping onto a carpet while operating a chainsaw.I have mine set to high gain and I do not hear any noise.
But, Amir places the threshold of audibility somewhere around 116dB if I remember correctly, and in the past has explained why he uses that value.
Ah, the audiophile "tweaking". What actual difference do you think the bitumen and fuses make to the audible sound quality?I am near to pull the trigger and buy 2 of them...The mere idea to build/mount his own amplifiers is somewhat thrilling and make them special to me. And I intend to make some "special tweaks" to personalize them further and make them unique. I have in mind the followings:
- 1.5m LS cable directly wired to the plate and out of the amplifier: So I spare 2 to 3 "connectors" which are always a weak point, and different cable types
- put some damping adhesive bitumen to increase weight and damping properties of the casing
- Upgrade the fuses (I have two spared SR fuses, so better to use it even if the effect on sound is much discussed...)
Does anybody of you see any other tweaking possibility/idea ?
Many thanks in advance
Bitumen = More weight/ damping = less vibrationsAh, the audiophile "tweaking". What actual difference do you think the bitumen and fuses make to the audible sound quality?
As to the effect of the fuses being "much discussed", it is like saying "the heliocentric model is much discussed" - yes, among flat earthers.![]()
Do you believe vibrations are an issue? How much of an audible difference do you think it makes?Bitumen = More weight/ damping = less vibrations
What would, in your view, be the explanation for any effect the fuse might have?Fuse = I don't know
Fair enough. Or you could just paint them pink.but at least it will not deteriorate the sound, and it will give me the impression (psy bias) that my amps are unique...
Don't neglect the psychological aspect !![]()
