Using the Nilai Stereo since 10 days now, AMAZING !
Thank you ASR for the review and a special thanks to
Dunlavyphile.
I am using Medium gain with the SMSL SU-9-PRO DAC and that just Rock !
I won't get into a subjective review ( ASR it's not the place ), but I will try to help other's.
FRONT PANEL LED ISSUE : this might help
I bought mine to KJF Audio, I took the "kit build service" so that I could use it directly
I remarked that the power Led was not working as expected... So I looked at the documentation and the assembly video
Discovered that the "CB-4" connected on J6 and J5 ( cf
nilai doc page 16 ) was not looking has it was in the video.
so I needed to exchange the side of this cable so that the red side would be as described here :
Plugging a cable in one direction or the other, should not change anything.
However the red drawings on the cable would normally help to identify each signal usage and they were not on the "good side".
Now I works fine
Maybe the cable had moved during the transport and changing the side would just help to secure the good connection ???
However the led works perfectly now.
I use the trigger input to power-on and off the nilai with the Node130 trigger outb function , that also very efficient
This is a picture of the "Wrong side" connection :
