As with
@Ropeburn, I'm confused as to what "timing is so off" means for an amplifier. Are you talking about left or right channel delay? If so, maybe there is something wrong with your system, or your particular amplifier. But, I still can't think of what would cause the right and left channels to be out of sync due to the amplifier itself. Perhaps the gain of the left and right channels are not matched, or you have a bad cable? You may need to troubleshoot your system to find the culprit. I have a Nilai, and don't have any timing issues whatsoever. Indeed, I haven't had timing issues with any amplifier I have owned, but I have had RCA cables go bad - the outer shield coming loose from the connector, probably from being moved around too much over the years. Still, that resulted in noise in one case, and loss of music in one channel in another case, not timing issues.
