Consider this one:Nice amp. Though I’m officially a Purifi guy, (AUDIOPHONICS HPA-S400ET Power Amplifier Class D Stereo Purifi 1ET400A 2x400W 4 Ohm), I’d consider this amp if I were in the market.
Wow, wish I needed one.
I also converted mine to be dual mono. With the second power supply, it does run warmer than stock. For mine, it was fine with both power supplies as long as I kept my cabinet door open, but it ran warmer than I wanted with the cabinet door closed (but still cooler than my old Adcom amp). Nonetheless, I added Noctua low noise/low rpm fans to the cabinet, and used the included low noise adapters (simple resistors that plugin in series with the fans). Now all of my amps run cool with the cabinet door closed, and I cannot hear the fans. The only time I can hear the fans is if the cabinet door is open and I am standing right next to the cabinet.The case gets quite warm to the touch after several hours of use, or on but sitting idle. I'm very happy with the performance of this amp and plan to keep it. One lesson I gleaned from this site is that heat is the enemy of electronic components so I would like to do what I can to improve cooling.
In stock form, I think long term reliability will be fine. I never noticed mine getting too warm, even with my cabinet door closed, until I modified it by adding a second power supply.I like the low profile look, on the other side I wonder if by having such a small case, will the heat impact the long term reliability.
As with many things in audio, it depends. But, generally speaking, class D amps do run cooler.Just curious as a non-engineer normie, do these class D amps ever get as warm as class A amps that people had for decades?
This is a review and detailed measurements of the Hypex Nilai500 DIY Stereo Kit Amplifier. Company sent me an assembled version. The kit costs €1,225.00 (ex VAT) or about US 1,490.
The case is rather hefty and I like its horizontal and thin configuration. Rear panel shows purely balanced connections and trigger input:
There are three internal gain settings. It was shipped to me set to medium gain and that is how I tested. For other gain settings see my review of Nilai 500 Mono Kit.
Hypex Nilai 500 DIY Stereo Amplifier Measurements
It is reassuring that the medium gain setting matched my previous testing of the mono kit:
Distortion if vanishingly low which causes SINAD to be dominated by noise which by itself is superb:
Left side of the chart indicates that for any 16 bit content you play, the amplifier is virtually noiseless eve at low power of 5 watts.
The same excellent class D amplifier technology is at play here with wideband gain, eliminating load dependency well into ultrasonics:
Crosstalk is excellent:
Multitone performance is superb above bass:
I didn't see the slightly elevated floor in mono testing. It is harmless though.
19+20 KHz intermodulation highly differentiates it from desktop class D amps with still superbly low distortion:
The amplifier protection circuit is quite aggressive in the way it shuts down the amplifier before much, if any, clipping occurs at 4 ohm. This made some of my power measurements hard as I had to choose much lower distortion levels (and as a result, reduce the reported power level). Still, there is plenty of juice visible:
For some reason, our power sweeps vs frequency were substantially better than my previous test in mono:
Finally the amplifier is stable on power up:
And only has a power off potential for noise:
The Nilai 500 stereo kit delivers state of the art amplifier performance with plenty of power. You can do slightly better in measured performance by giving up more power -- something I like NOT to do. With 300 or so watts power on tap into 4 ohm, you will be able to drive just about any speaker to very loud levels, reducing the anxiety over what amp to buy.
Needless to say, it is my pleasure to recommend the Hypex Nilai500 DIY Stereo Kit amplifier.
Great amp but a bit expensive...
Will take a look at the Purifi 1et9040ba first, checkout APx555 measurements here :
Fresh From the Bench: Purifi 1ET9040BA Balanced Class-D Amplifier Module
The Purifi 1ET9040BA balanced Class-D amplifier module, a Bridge-tied-load (BTL) output stage, is the second product in the company`s Eigentakt range. Following a conversation with members of Purifi about the amplifier`s audio performance being hard to measure even with the best available test...audioxpress.com
It's truly remarkable how Bruno Putzeys consistently delivers. The man is a living legend!
Life on the Edge - A Personal Perspective on the Past, Present, and Future of Class D Audio Amplifiers - HomeTheaterHifi.com
The past quarter century of class D developments look strikingly different when seen through the eyes of the audio consumer and through...hometheaterhifi.com
And he's also a fantastic explainer of technical concepts:
He left Hypex 11 years ago. The man is brilliant but I have some doubts on his capacity to do electronics development for companies he doesn't work for.It's truly remarkable how Bruno Putzeys consistently delivers. The man is a living legend!
Nilai was once the king of class D before 1ET6525SA came out.The French can be proud of their Audiophonics.fr
And the 1ET6525SA module is able to deliver us also some exceptional clean Watts (even as an integrated and completely build amp):
AUDIOPHONICS HPA-INT450ET Amplificateur Intégré
Audiophonics est fiers de vous présenter le HPAINT-S450ET. Cet amplificateur intégré de Class D repose sur une paire de modules d’amplification Purifi 1ET6525SAwww.audiophonics.fr
without Preamp:
AUDIOPHONICS HPA-S450ET Amplificateur de Puissance Purifi 1ET6525SA
L'amplificateur de puissance Audiophonics HPA-S450ET se base sur une architecture classe D, utilisant deux modules Purifi 1ET6525SA, une alimentation Hypex SMPS1200A400 et un étage buffer custom Audiophonics pour des performances d'exception...www.audiophonics.fr
I'm not sure where you are going here. Just because he left Hypex doesn't mean he is not still contributing great designs to the audio industry. Indeed, the Purifi Eigentakt class D amplifiers and Kii speakers are extremely well engineering products.He left Hypex 11 years ago. The man is brilliant but I have some doubts on his capacity to do electronics development for companies he doesn't work for.
They are both fantastic products.Nilai was once the king of class D before 1ET6525SA came out.
Depends on how much cooling each has. My desktop CPU runs cooler than a typical phone.Just curious as a non-engineer normie, do these class D amps ever get as warm as class A amps that people had for decades?
Just replying to a person thinking that this product was designed by BP while it was not. I do not see what the problem is.I'm not sure where you are going here. Just because he left Hypex doesn't mean he is not still contributing great designs to the audio industry. Indeed, the Purify Eigentakt class D amplifiers and Kii speakers are extremely well engineering products.
