Hypex NCx500 Class D Amplifier Review
Rate this amplifier:
    Votes: 4 0.8%
    Votes: 7 1.3%
    Votes: 61 11.5%
    Votes: 457 86.4%
Sounds awesome. How is it different?
The Buckeye 3-channel NCx500 is using the 2,000W SMPS from Micro Audio (SMPS2K-SN) that is 93% efficient. With losses, assuming 90% efficiency, you can get 600W per channel at the lowest impedances. For the price of $1550 USD delivered (for a US customer), this performance is excellent.
Similarly, boXem has their A 5519/N3 3-channel NCx500 using the Hypex SMPS3k which can deliver 3,000W with over 90% efficiency which can easily provide 600W per channel. For US customers it comes out to roughly $1950 USD delivered. This is also a great price for performance.
absolutely not comparable. The SMPS3K should be renamed to SMPS1.0 .. continuous power output is just 1000w .. no active PFC etc .. I can beat the Microaudio SMPS for several minutes without any voltage drop or overheating. Idle standby is way lower .. i built 16 8-channel amps and a friend as well .. he used the hypex, i used the microaudio. i have less than half power on idle consumption as well as lower standby.
I have first hand use of the Micro Audio SMPK2K-SN in the Buckeye and it’s excellent for the Revel F228Be & C208 LCR. The Hypex SMPS3K looks promising, so I was thinking to get one.
Respectfully, could you explain more about your experience?
What shall i explain .. ask precisely ? .. i built enough to be happy :) and Microaudio is able to customize with comparable small quantities .. i asked for Mundorf Mlytic Caps - done .. Sparks Voltage regulator .. done .. Wago connectors ... done ...
Comparison with the Hypex SMPS3k. Output power with all channels active, overheating, clipping, distortion and so on.
That's a nice build! You've got two power supplies, solid copper heat sink on each of the 8 channels with a backplane and a large cooling fan on the side. It must weigh close to 60 pounds.
I measured only single SMPS .. but as both have independant power sockets ... 2200w @ 240V for 3 minutes 20hz sine wave torturing .. then i stopped. there was no heat buildup at that time ... pretty sure that would run way longer without any hassle, but as i don't plan to use them as welding power supply i stopped after 3 minutes. 20hz sine for that duration is far off any real world usecase. i did not measure distortion, sorry... my main goal was to build a silent amplifier as compression driver in home cinema and 15 speakers the idle noise sums up and now it is dead silent.
I don't know anything about these amps and how they work but I know my current Nord One NC500 MKII Dual Mono is the best amp I've owned.
My Nord One NC500 MKII Dual Mono Stereo Power Amplifier has Sonic Imagery 994, connected to a Music First Audio Passive Baby Reference V2 Pre-Amplifier, connected to a pair of Boeniche W11 speakers.
I'm thinking of upgrading to this latest module NCx500.
Do you think it is worth doing?
If it is worth doing, is there anything I should think about concerning my pre-amp for instance?
The improvement is subtle. If everything else is optimized already, then it might be worth. Else money is better spent on acoustic treatment for example, or room correction etc.
My music room has GIK panels all round including the ceiling.
So you think it might be worth it?
Depends on what you value, and what you expect the upgrade to bring to the table.
Most likely it'll just bring the noise floor down from very low to extremely low. Your speakers aren't very sensitive/efficient, so I very much doubt you're having any issues with hiss, meaning an audible upgrade is also very unlikely to happen.
People tend to have great difficulty telling amplifiers apart, even "dirty" PA Class-D amps, when doing so without any other knowledge than the sound itself. As long as an amplifier isn't clipping, or have a high enough noise floor to give audible hiss from you speakers because of the gain structure of your system, it'll have to be really horrifically badly designed, either deliberately or from lack of diligence, in order to present anything remotely close to a "sound signature". At least that seems to be the recurring conclusion, when these things are being tested properly.
I am now the owner of a brand new Nord One SE NCx500DM MK II.
I was having so much updated on my old Nord amp that it made better sense to buy a brand new one.
This amp is quite a bit better than the NC500: Better separation, more detail and tighter bass.
Well worth the upgrade :)
If you say so... :)
what made you choose the NCx500 MKII over the NCx500? I'm a little blinded by choice, myself.
Hi amigos
I just zoomed the Buffer used into this review and this is the genuine Hypex NC500 buffer by Hypex and it was plugged into the NCX500 without any issue apparently....
Genuine NC500 buffer
https://www.hypex.nl/products/accessories/evaluation-boards/nc500-evaluation-board
any idea ?
As far as I know The two regulators on the NC500 buffers create ±12 V for VAUX. That works well for the NC500 and Purifi but normally not for the NCX500 that requires a minimum of ±15 V. You can read that in the NCX500 user manual....
BTW : NCX500 and NC500 are pin to pin compatible. As you know the NCX500 has voltage regulators + OP amps directly onboard.
I made a test with Nautile active speakers based on NC500 modules. I removed the old NC500 and replaced it by the NCX500 and worked 100 % nice ) Another weird thing : you can replace any NC500 modules by NCX500 with all Nord NC500 amps it works @100 %
what preamp does this?
I Use the ADI-2/4 Pro from RME driving the NCx500 (11dB amplification).
According the manual the ADI-2/4 Pro delivers:
The maximum of 26.5dBu is 16.3Vrms. Even the 24dBu = 12.2V are still enough to get full power.
Best DrCWO
