Summary
This post summarizes information to changes the Hypex NC400 gain to 12dB "low gain" (from 26dB "high gain") by removing the Rg resistor from the instrumentation section. With lower gain, the amp clips above 9.6V rms instead of 2V*.An added bonus is that padding, i.e. gain reduction, cuts noise in half and results in an additional 6dB of SNR resulting in a performance comparable with the AHB2, Purifi, and Nilai amps.
Warning: this modification requires soldering and will void any warranty.
* The lower line level is useful when the amp is used with pro audio gear like RME or MOTU. Line level consumer audio typically clips between 2-4V, line level pro audio gear above 12V.
Principle
The NC400 has an instrumentation amp section with gain is Av=(1+2*Rf/Rg)=4.7=13.4dB, where Rg=1.2k and Rf=2.2k.It is noted that the instrumentation amp is omitted in the Purifi amp. This reduces the gain by 4.7x and, results in differential amp at 4.4x or 12.8dB gain, but with a low input impedance.
It is possible to achieve the same gain optimization by setting removing Rg=inf, i.e. removing Rg (R141 on the PCB - red rectangle). The modification retains the NC400 high input impedance.
My modified 4xNC400 "low gain"
Measurements (credit Langston @ Klipsch community)
Benchmark AHB2 (for reference):
NC400 before mod "high gain":
NC400 after mod "low gain":
Thoughts
The gain is mostly relevant in setups that run professional (or high-gain) interfaces or DACs. I only did this modification to achieve a better gain match in my system (without inline attenuators).The 6dB noise improvement is a nice benefit. It is quite plausible that is also observed in the Hypex Nilai500DIY measurements (link). It is good to see that the NC400 benefits from this too.
Reference and measurements
miniDSP SHD Power & Hypex NC400 Class D Amps
community.klipsch.com
