Yes indeed, I'm definitely glad that removing the resistor was an easy and quick option for me . Also great for those who have sensitive speakers, and need to get that amplifier gain down.The resistor delete makes sense in your setup, Bruno didn't do it because super high output level dacs weren't a thing back when the ncores and prior hypex amps were being developed. That's a win.
As I stated previously, I'm open to measurements, but I simply don't have the appropriate equipment. I don't want to ship my amplifiers oversees to be measured, but if someone living in my country (or nearby) was curious and willing to come by and measure them, I'd welcome that.The capacitors COULD be a win, but only measurement of just that mod alone will prove that beyond doubt. I've done the same in phonostage riaa caps before for a truly tiny improvement in self noise.
Care to elaborate further on your thoughts/concerns? EMI/EMC has been brought up previously, and that is a legitimate issue, but I haven't experienced any issue because of it (i.e. the sound from the amplifiers is great).I'm less inclined to believe in the inductor.
I suppose the only answer for this is also - measurements!And your wires still need to be twisted, without any doubt.
This was indeed case for me, as I was using the digital volume control in my DAC and typical listening levels meant attenuating between -20dB to -40dB.
Perhaps, but that is unnecessary in my case, as I already have a DAC with an exceptionally low noise floor. You'd need an equally reference level pre-amp to match the objective performance and I'd rather spend my money elsewhere (such as for mods! ).
While on the topic of mods and for those interested, another quick and easy one is to upgrade any fuses. In the case of the NC400 DIY kit, there is 2 fuses, 1 in the IEC connector and 1 in the power supply. Note that in my case, I replaced the stock IEC connector and the new one does not have a fuse anymore.
In the image below, I replaced the stock ceramic fuse (8A slow blow) in the SMPS600N400 power supplies with an equivalent one from HiFi-Tuning (in my case the Supreme 3 Silver Fuse). Note that this fuse is directional, meaning that the arrow on the body of the fuse needs to point in the direction of conventional current flow as shown below. If you place it the other way around, it just won't sound right (strange eh?).
Safety note: Replacing a fuse can be dangerous if you don't know what you are doing. Always ensure that you disconnect all power from your amplifier (i.e. Don't just use the off switch if there is one), but completely unplug all power cables and let the module rest/cool off if it had been switched on previously, before attempting to do anything. As previously stated for the other mods, attempt at your own risk and be aware that your warranty may be void.
I was motivated to try a fuse replacement/upgrade, based on the experience and reports of others who have previously done so on other forums. That's part of the magic of DIY, is to try and experiment with new things and explore different perspectives, even if at first you don't think it will make any difference. You don't know for sure, unless you try it for yourself, and success or failure is part of the journey.While I can appreciate making mods based on solid research, what made you think that removing the mains fuse would have an audible improvement (and so much so that you are willing to forgo the risk of potential shock/electrocution)?
Is that enough to explain possible audible differences? Probably not, so depending on what you believe and if you are curious, all there is left is to try it for yourself and/or pull out the measuring equipment.Ordinary fuses consist of a glass tube, with on either end small steel caps with a layer of nickel over it. Neither of these parts are ideal. The ideal fuse for audio has to start with a ceramic body, in which should be mounted a silver fuse wire. This wire is connected to end caps made from pure silver, that was covered with copper first, then gold plated. To top things off, all fuses are then demagnetized and cryogen treated for even better conductivity, and less distortion and noise.
Fuses always carry a high current that easily evokes metal fatigue. This causes a degradation of the conducting properties of the fuse wire, thus resulting in a degradation of the equipment in which this fuse was mounted. The HiFi Tuning fuses will have up to 90% less losses than prescribed by the IEC. The HiFi-Tuning fuses are 24 carat gold plated. On one hand, many fuses contain a spiralised fuse wire, that causes a high resistance and inductance. On the other hand, we have the HiFi-Tuning fuses that contain a straight fuse wire made from pure silver. This results in a very low resistance and a negligible inductance.
Is there anything specifically about the original mods that you disagree with?You started this post with stating how much you researched and you stated some references earlier, but appears to get less and less fact based as it goes forward. Can you please share more of the science behind each mod? Thanks!
I have highlighted two statements here.Mola Mola Website said:The audio circuitry is trimmed to the bare bones and board-to-board connectors are eliminated in favour of soldering star-quad cables directly into the circuit board for the cleanest, lowest impedance connection possible. The input stage is implemented on a separate circuit board that uses the same discrete buffers as those found in the Makua. The output filter sports monolithic capacitors whose dielectric stability is reflected in an impressively neutral and poised rendition.
In the simplest case, all that needs to be done is to remove SMD resistor r141 in order to achieve the lowest gain. Given the amount you are attenuating by, this is the way to go. If you know someone who is experienced with electronics repairs, perhaps ask them and see if they can do it. Visiting a dedicated repair shop or similar is also an option.Personally, I wouldn't mind lowering the gain of my NC400s as I'm usually in the -30 region of my DAC, but I'd rather not do that through soldering.
I think you are being overly dramatic. What would happen if you actually visited a dedicated DIY electronics forum. Perhaps call the electronics police in a panic at everything that people are experimenting with? Please be aware that the usual warnings (at your own risk, may void warranty etc..) was one of the first things I noted in my original post and our vigilant moderators then added any additional warning they deemed appropriate.I second your and add an !
This thread is a case study of how internet lore is too often used as justification for ignoring known engineering science. It is so alarming and disturbing, that I will simply repeat this…
The reason why I began my investigation into these modifications, is because I was not fully satisfied with the sound from my NC400s. In the end, it came down to two options, sell them and try something else, or try to modify them. As previously referenced in the thread, the designer of the NCORE modules himself acknowledged and clearly stated that the use of an iron core inductor was the source of an audible flaw - that definitely caught my attention (i.e. was this what was contributing to my displeasure with the sound?). If that is not reason enough to explore options for making changes, then I don't know what is. If an NCORE owner is happy to live with a sonically flawed product, that's fine, but not for me and I'm sure other owners will feel the same. As for the unaware, perhaps ignorance is bliss.Am not sure of your credentials, but your claims do not pass good engineering practice for me. Within my engineering experience, we would say “just because you can make a change, does not mean you should”. It may be that the change is a poor return on investment, would take too long to make, or negatively affects quality or safety. Many of your mods are questionable return on investment IMO.
I apologise for not being able to afford an APx555B.ASR is not about being like other forums as you seem to acknowledge. There is a greater need to demonstrate scientific proof and objectivity here. Several reputable members have questioned your claims and you continue to fail to provide credible proof. The burden is on you to show scientific credibility. DIY experimentation is supported on ASR but scientific scrutiny is part of it. Expect nothing less!
The flaws from iron core inductors are corrected by post filter feedback, not by replacing them by EM antennas. This is valid for UcD, Ncore, Eigentakt and a few others. So these flaws cannot be heard since they are already corrected with these amplifers. Describing Ncore as a "sonically flawed product" is an interesting affirmation.The reason why I began my investigation into these modifications, is because I was not fully satisfied with the sound from my NC400s. In the end, it came down to two options, sell them and try something else, or try to modify them. As previously referenced in the thread, the designer of the NCORE modules himself acknowledged and clearly stated that the use of an iron core inductor was the source of an audible flaw - that definitely caught my attention (i.e. was this what was contributing to my displeasure with the sound?). If that is not reason enough to explore options for making changes, then I don't know what is. If an NCORE owner is happy to live with a sonically flawed product, that's fine, but not for me and I'm sure other owners will feel the same. As for the unaware, perhaps ignorance is bliss.
Here is the quote from the audioxpress article referenced in my original post:The flaws from iron core inductors are corrected by post filter feedback, not by replacing them by EM antennas. This is valid for UcD, Ncore, Eigentakt and a few others. So these flaws cannot be heard since they are already corrected with these amplifers.
The flaw can be heard, as stated in the article. It was the complaints from the listeners that lead to the investigation, with the conclusion being that the iron core inductor was the source. Why are you insisting on contradicting the statements from the article?His NCore amplifiers were touted to be more linear than any other amplifier in any other class, but some recent products challenged that statement, so it was time for a next leap forward. Sporadic reports of a sort of “granularity” in the sound reproduction also prompted an investigation into whether this indeed happens, and if so, what would be the cause.
It is a fair conclusion, given what is stated in the article. It is part of the reason why the Purifi was developed.Describing Ncore as a "sonically flawed product" is an interesting affirmation.
I am not used to change the conclusions from a reflexion based on logic and education because I read whatever article on the internet. Can you find an interview or a paper from BP with such a statement?Here is the quote from the audioxpress article referenced in my original post:
Purifi has a nice technical breakdown and examples of hysteresis distortion here: Purifi - This Thing We Have About Hysteresis DistortionI am not used to change the conclusions from a reflexion based on logic and education because I read whatever article on the internet. Can you find an interview or a paper from BP with such a statement?
Well that description goes in the direction of what I had been disliking in regards to the sound from my NC400s. So coming back to your previous statement, it is actually UcD and NCORE that have this audible flaw. Bruno claims to have resolved it with the Purifi using an improved feedback design.Purifi Website said:Hysteresis distortion isn’t something that we simply decided to big up in search of a USP. It’s very real, very different from what you’d expect and not at all subtle. It takes the form of popping or crackling noises that go off at almost but not entirely random moments. You can’t rely on masking to render it inaudible because cause and effect are not coupled in time and the distortion level tracks the signal level.
It is not like normal distortion that the ear just files away as colouration, or can otherwise get used to. Left to its own, hysteresis produces a recognisable grainy texture in the sound, a blanket of fuzz that always stays just this side of audible, taunting and infuriating like an itch you can’t scratch.
This is why we put so much effort into removing it from our amplifiers and speaker drivers.
This brings back up the concern you raised previously, that using an air core inductor may cause issues with EMC. In my own case, I have not experienced (audible or otherwise), any issue in regards to EMC/EMI with the air core inductor in place. But that is not to say that it can't be an issue - everyone's environment is different.Purifi Website said:You might fix hysteresis distortion by putting in a chunky air coil (thus failing EMC and needing extra filtering to pass).
The second article is entirely about post filter feedback as a solution and very briefly explains that air core inductors are NOT a good solution.Purifi has a nice technical breakdown and examples of hysteresis distortion here: Purifi - This Thing We Have About Hysteresis Distortion
Quick summary for those who don't want to read the whole article:
Additionally, here's another article regarding hysteresis from Purifi: Combating Hysteresis Distortion (part 1: Amplifiers).
Here's a brief excerpt from that article, which you may find of interest:
So put simply, if you are a UcD and/or NCORE owner and you are looking for an upgrade, you can consider these modifications, or save yourself any risk and effort and simply purchase the Purifi knowing that it resolves a previously well defined and known audible issue.
The air core inductor is a valid DIY solution, with its own caveats as noted. From a large scale commercial company perspective however, I can understand that the air core solution would not be ideal, due to a much higher material cost, larger physical size and having to deal with EMC regulations, which are all valid reasons why Bruno would not take such an approach.The second article is entirely about post filter feedback as a solution and very briefly explains that air core inductors are NOT a good solution.
It is not bs at all. I'm sorry, but you are clearly in denial now. NCORE is audibly flawed, as outlined in the article regarding Bruno's technical presentation on the issue of hysteresis and all the technical articles they wrote about it at Purifi. I understand that the truth can hurt, but it is what it is. So accept it, move on, and perhaps like I suggested previously, let's figure out how we can measure and quantify such audible flaws on this forum, so we can avoid products with this problem in the future.But please, stop advocating them as panacea for correcting a supposedly bad sounding Ncore. That's utter bs.
I appreciate you having taken the time to discuss this here with me.That said, I will stop here. I have a company to run and some actual engineering to do. Have fun.
Nice! where can I find this schematic? That's way better for me to do modifications on the nc400 board, could you please share this if possible?For those interested, an excerpt from the NC400 schematic showing the LC filter circuit with the appropriate inductor and capacitors highlighted:
