It‘s rather that the Amp might be built to handle higher than 2 V maximum. Probably with this speaker its not a problem at all. Even seems to be a perfect match as the calculated power is a perfect match with the speakers specs.
You should be absolutely fine unless the speakers are often run at their maximum recommended power levels. In this case, maybe, you could get more „impact“ in some higher volume parts of some tracks.
If that would be a problem, you could still add an external XLR DAC with higher voltage to the node. (Like the SMSL SU8)
Did some GPT-Math. (no guarantee on correctness):
Step 1 — voltage gain factor
G = 10^{\frac{25.5}{20}} \approx 18.8365
Step 2 — output voltage (RMS)
V_\text{out} = 2.00\ \text{V RMS} \times 18.8365 \approx 37.673\ \text{V RMS}
Step 3 — power into 6 Ω
P = \frac{V_\text{out}^2}{R} = \frac{37.673^2}{6} \approx 236.54\ \text{W RMS}
Step 4 — resulting SPL (1 m)
Speaker sensitivity = 88 dB (1 W @ 1 m). Increase from 1 W to 236.54 W:
\Delta_\text{SPL} = 10\log_{10}(236.54)\approx 23.74\ \text{dB}
So SPL at 1 m ≈ 88 + 23.74 = 111.7 dB SPL
For quick reference, approximate SPLs at common listening distances (spherical 6 dB per doubling of distance):
- 1 m: ≈ 111.7 dB
- 2 m: ≈ 105.7 dB
- 3 m: ≈ 101.7 dB
Conclusion (short):
Yes — 2 V RMS into an amp with 25.5 dB gain theoretically produces about 237 W into 6 Ω, giving ~112 dB at 1 m from an 88 dB/W/m speaker — which is very loud for domestic listening.
