I'm building a Hypex NC252MP amplifier in a Ghent case and I am considering improving the cooling.
Could I mount heat sinks on the sides internally to increase the surface area?
Could I mount the amp board towards an upside down large heat sink with short fins, but could a problem with grounding and heat transmission to the rest of the chassis?
Could I mount the amp board on a larger aluminium plate to disperse the heat better to the chassis?
Is there a solution for a fan kit, mains powered from the mains input, or do the amp board have 12v power output for a fan? Is there a kit with a set or programmable thermostat?
