Only if you are a dog or a bat named Eric.
Don't forget cows...16-40khz...
Yes, and as seen on the permeability table, distance (air) is almost equal to aluminum, both vastly inferior to sheets of iron, steel or mu-metal.
jalejos is testing the Hypex NC1200 modules and the buffers designed by him for the NC500 in conjunction with Richard Doporto (Sonic Imagery).
For this, he is temporarily using a provisional box, the NC500 in stereo, until the design of a mono box for the NC1200 ends. That is why everything is so tight, it is too small.
The buffers are the same as those of the NC500 except for a few minor modifications, as he told me in the long email received in response.
http://www.atmstore.es/en/
https://www.facebook.com/ATMStoreValencia/
Search function is your friend:Have measurements been done on the nc1200?
As it is said it should be better than the nc500?
From measurements it looks like the nc500 is better then the nc500. Is that true?
Haha meant NC400....The nc500 should be about the same as the nc500.
No it really was funny
Which with the Hypex design they have. Please look at the plots I showed of the LACK of RF coming out of the units. If you dont understand the plots please ask for clarification.
In this implementation there is a little linear psu connected to a 1200smps do you know the rason?The first, the original, the expensive... the Bruno Putzeys implementation.
Mola Mola Kaluga mono
https://www.mola-mola.nl/kaluga.php
Certainly to have a standby function compliant with EU regulations. The SMPS used doesn't have it embedded.In this implementation there is a little linear psu connected to a 1200smps do you know the rason?
Thanks
Pit
From the pictures, the SMPS aux seems wired the the amplifier module.https://www.audiosciencereview.com/forum/index.php?threads/diy-purifi-amp-builds.10478/post-323538
Clean AUX power, better than from Hypex SMPS.
This looks more like marketing verbiage that facts, I hope you will as well relay my own marketing once I start selling products .https://www.audiosciencereview.com/...io-class-d-amp-build-quality.7717/post-182097
[ ...In attachment you can also find pictures of our new amazing product. It is called the PNC1200M mono blocks. PNC stands for Premium Ncore. These mono blocks are based around the NC1200 modules. We use Weiss OP2-BP op amps for the input buffer and a linear power supply for the input buffer stage and modulator stage... ]
Thanks
Pit
Apollon flagship PNC amplifiers
Thanks
Pit
I am more concerned by the fact that the case is very small. There must be a horrible heat build up.
Maty would disapprove ;-)
